はじめに
If the hem of your towel has come undone and there are loose strings, use this guide so that the rest of your towel doesn't start to unravel.
Before you pick your thread, I would recommend using a color that matches your towel. I picked a darker color so that you could see the stitches I created.
This is also a project that you can do a bit at a time if you need a break.
This guide is designed to help people who do not have a sewing machine at their disposal. You are welcome to use a sewing machine if you'd rather, but the tools listed will help anyone complete this project easily by hand.
必要な工具と部品
Use sewing scissors to cut a piece of thread twice the length of your arm.
Push one end of the thread through the hole at one end of the needle.
Hold both ends of the thread in your hands.
Make a knot at the very end of the thread.
Working from front you back, insert your needle and pull it all of the way through.
Go about a half inch to the left and insert your needle back to the front.
Going another half inch to the left, repeat these steps and stitch evenly along the lower edge of the hem until you reach the end of the towel.
Hold both strands to make a knot close to the towel and trim the ends.
Knot your new thread and insert it close to your recent stitch, coming back through.
Put your needle under the line of thread you just recently stitched to the right, pulling your thread almost all of the way through.
Put your needle under the thread from your current stitch.
Like in the third picture, you will want to pull the loop at the top until you have a flat line across.
Pull your thread all of the way through to make it stay.
Go back through your initial hole towards the back, then come up through to the front on the other side of your current stitch.
I am right-handed, which is how this guide was designed. The steps should still work, even if you are left-handed or decide to start with the left corner. Thank you for taking care of your towels!
ある他の人がこのガイドを完成しました。
