メインコンテンツにスキップ
How to Repair a Torn Stuffed Animal
必要な工具と部品
  1. How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: 手順 1、 3の画像 1 How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: 手順 1、 3の画像 2 How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: 手順 1、 3の画像 3
    • Gather all of your materials.
    • Pinpoint the tear in your stuffed animal.
    • Measure out the desired length of thread that will fully cover your tear.
    • The amount of thread that you use will vary depending on the size of the hole. However, it is always better to use too much thread rather than too little.
  2. How to Repair a Torn Stuffed Animal: 手順 2、 1の画像 1
    • Push the thread through the hole of the needle. Make sure to pull the thread all the way through.
    • Working with needles can be dangerous.
    That's great but I need to fix it with hem tape is that possible
    Sue Armstrong - 返信
    That's great but I would like to use hem clothing tape is that possible
    Sue Armstrong - 返信
  3. How to Repair a Torn Stuffed Animal: 手順 3、 2の画像 1 How to Repair a Torn Stuffed Animal: 手順 3、 2の画像 2
    • Take both of the threads and match up their ends.
    • Double knot the two ends together.
  4. How to Repair a Torn Stuffed Animal: 手順 4、 1の画像 1
    • Cut off any excess thread at the end of the double knot.
  5. How to Repair a Torn Stuffed Animal: 手順 5、 1の画像 1
    • Bring the sewing needle to the top of the tear in the fabric.
    • Push the needle in through the interior of the fabric.
    • Putting the needle on the inside of the fabric hides the knot.
  6. How to Repair a Torn Stuffed Animal: 手順 6、 3の画像 1 How to Repair a Torn Stuffed Animal: 手順 6、 3の画像 2 How to Repair a Torn Stuffed Animal: 手順 6、 3の画像 3
    • Begin stitching up the tear. Bring the needle from the starting side over to the other side of the tear.
    • Push the thread through the top of the fabric.
    • Bring the needle back over to the starting side and pull it back up through the interior of the fabric once more.
  7. How to Repair a Torn Stuffed Animal: 手順 7、 1の画像 1
    • Continue stitching up the tear until you reach the end of the tear.
  8. How to Repair a Torn Stuffed Animal: 手順 8、 1の画像 1
    • On your final stitch, pull the needle and thread through the loop.
    • Repeat this step once more to make sure your knot is secure.
    • Pull the needle tight.
    • Don't pull the needle too tight so that you break your thread.
  9. How to Repair a Torn Stuffed Animal: 手順 9、 1の画像 1
    • Cut the end of the thread once the knot has been secured.
ゴール
47 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Gracie Campbell
メンバー登録日: 09/29/15
1,551 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015人のメンバー
CPSU-GREEN-F15S17G5
4 メンバー
11のガイドは作成済み
10 件のコメント
I have a vintage Mickey Mouse (1970s) he has red velvet shorts with yellow felt buttons. It looks like they were just attached by adhesive when made. One of the buttons have been lost due to time and left a bare patch of velvet. I am unable to find hints or suggestions on how to repair our Mickey. It was my husband's as a child and our youngest was in love with it until the button disappeared. He wont play with it now because he think he hurt it. Any help would be greatly appreciated.
Heidi Carstens - 返信
You could sew on Another button, I'm sure you could find a very similar button on Amazon and quickly thread it back together, good as new. If you need any more help, just let me know :)
Zara Hunt -
How about you try to make a duplicate button and sew it on to your Mickey. You can probably make one by cutting two pieces of yellow felt fabric and sewing them together, you can then sem the button on Mickey where the bare patch is. If it looks awkward, then you can make another button and replace it with the other (original) button if it looks different from the new one you made. You can always make a new button, but maybe not an original one.
By doing this repair, you might take some of the vintageness out of Mickey, but your son would be happy and play with him again. Which is more important? Don’t forget the reason why Mickey was made in the first place. You'll be restoring Mickey’s purpose of being played by children again!
Omar Farid - 返信
Simple and easy to follow instructions! Thank you so much!
I’m still only learning to sew, and a dog we were looking after decided to chew on my little sister’s FAVOURITE unicorn stuffy, and left a HUGE tear in it. Searched for ages to find instructions on how to sew it back up, but they were all extremely complicated, overdone, or way too confusing to follow. This one, however, was amazing! I was able to fix it for her like new! Thank you!
Maddy Smith - 返信
I have a Large Fireman Sam Plushie and between the feet and the legs the stuffed toy is ripped. What should I do?
Fireman Sam UK - 返信
Thanks It was fun to fix my toy
Noah Kinsler - 返信
i have a beenie baby with holes and this did not help but i thank you for help thou
Izzie Murray - 返信
My mini Doxie likes chewing on her toys still at 12 years old, and all the stuffed animals would eventually come undone from my oh not so spectacular sew job. I can do alot of things but it seems sewing is the elusive hobby and trait. I never could successfully sew anything. I'm hoping I followed the instructions completely, and it doesn't come unravelled. The 2 things done different are starting on the inside and then double knotting in the beginning and end. I never could get my threads to knot properly. Thank you for this handy guide. Pictures help alot.
amandacooper39 - 返信
I only have thick thread and I have no other material and my most precious toy ripped and I don't know what to do :(
Kat - 返信
ich habe ein Kuscheltier und bei dem fehlt ein Bein wie kann ich das wieder dran nähen?
Leon Pohl - 返信
コメントを追加
統計データ:
過去 24時間: 35
過去 7 日: 214
過去 30 日: 1,039
今までの合計 126,247
