メインコンテンツにスキップ
How to Repair a Stuck or Broken Chainsaw Rope
必要な工具と部品
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: 手順 1、 2の画像 1 How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: 手順 1、 2の画像 2
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: 手順 2、 1の画像 1
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: 手順 3、 2の画像 1 How to Repair a Stuck or Broken Chainsaw Rope: 手順 3、 2の画像 2
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: 手順 4、 2の画像 1 How to Repair a Stuck or Broken Chainsaw Rope: 手順 4、 2の画像 2
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: 手順 5、 1の画像 1
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: 手順 6、 1の画像 1
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: 手順 7、 1の画像 1
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: 手順 8、 1の画像 1
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: 手順 9、 2の画像 1 How to Repair a Stuck or Broken Chainsaw Rope: 手順 9、 2の画像 2
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: 手順 10、 1の画像 1
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: 手順 11、 2の画像 1 How to Repair a Stuck or Broken Chainsaw Rope: 手順 11、 2の画像 2
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: 手順 12、 1の画像 1
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: 手順 13、 1の画像 1
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: 手順 14、 1の画像 1
    • Pull on the rope to make sure the chainsaw works.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Matthew Whetzel
メンバー登録日: 02/22/21
247 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G7, Raign Spring 2021 University of North Texas, Team S1-G7, Raign Spring 2021人のメンバー
UNT-RAIGN-S21S1G7
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 395
