メインコンテンツにスキップ
How to Repair a Stuck Trailer Jack
必要な工具と部品
  1. How to Repair a Stuck Trailer Jack, How to Repair a Stuck Trailer Jack: 手順 1、 1の画像 1
    • Remove the trailer jack from trailer.
    • Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
    • Slide the jack off the trailer to remove.
    • Be sure to safely support the trailer before removing (With a vehicle or jack stands).
  2. How to Repair a Stuck Trailer Jack: 手順 2、 1の画像 1
    • Remove the nut and bolt that secures the handle to the jack.
    • Use two half-inch box end wrenches to remove the half-inch bolt and nut.
    • Slide the handle upward after removing the nut and bolt to remove the handle.
    • Set the handle aside.
    • Screw the jack to the most extended spot the jack will go.
  3. How to Repair a Stuck Trailer Jack: 手順 3、 1の画像 1
    • Lift the spacer or washer upward.
    • Set the washer aside.
  4. How to Repair a Stuck Trailer Jack: 手順 4、 1の画像 1
    • Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
    • Set the upper assembly aside.
  5. How to Repair a Stuck Trailer Jack: 手順 5、 1の画像 1
    • Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
  6. How to Repair a Stuck Trailer Jack: 手順 6、 1の画像 1
    • Apply grease or anti-seize lubricant to the screw assembly.
    • Screw the screw assembly to full extension and shortest extension to ensure lubricant reaches every section of the screw assembly.
  7. How to Repair a Stuck Trailer Jack: 手順 7、 1の画像 1
    • Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
  8. How to Repair a Stuck Trailer Jack: 手順 8、 1の画像 1
    • Paint the upper and lower assemblies for prevention of future rust and corrosion.
  9. How to Repair a Stuck Trailer Jack: 手順 9、 1の画像 1
    • During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
  10. How to Repair a Stuck Trailer Jack: 手順 10、 1の画像 1
    • Use a hammer to force the upper assembly over the lower assembly.
    • Be sure to align the grove and notch of the assemblies.
  11. How to Repair a Stuck Trailer Jack: 手順 11、 1の画像 1
    • Install the washer and the jack handle over the stud of the jack.
    • Insert the bolt through the handle and the hole located on the stud.
  12. How to Repair a Stuck Trailer Jack: 手順 12、 1の画像 1
    • Install the jack to the trailer and test for correct operation.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cody Gearin
メンバー登録日: 03/25/20
336 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S5-G10, Willis Spring 2020 University of Memphis, Team S5-G10, Willis Spring 2020人のメンバー
UM-WILLIS-S20S5G10
1 メンバー
2のガイドは作成済み
コメント 1 件
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
Loren Turner - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 109
過去 30 日: 480
今までの合計 19,696
