メインコンテンツにスキップ
How to Repair a Stuck GameCube Eject Button
必要な工具と部品
  1. How to Repair a Stuck GameCube Eject Button, How to Repair a Stuck GameCube Eject Button: 手順 1、 3の画像 1 How to Repair a Stuck GameCube Eject Button, How to Repair a Stuck GameCube Eject Button: 手順 1、 3の画像 2 How to Repair a Stuck GameCube Eject Button, How to Repair a Stuck GameCube Eject Button: 手順 1、 3の画像 3
    • Turn off the GameCube and unplug the power cable from the back of the device.
    • Ensure that all power is disconnected to ensure no damage is caused to the device or yourself.
    • Remove any discs from the disc tray. Unplug any controllers or memory cards from the front ports.
    • Place the GameCube upside down.
  2. How to Repair a Stuck GameCube Eject Button: 手順 2、 3の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 2、 3の画像 2 How to Repair a Stuck GameCube Eject Button: 手順 2、 3の画像 3
    • Remove all four 4.5 mm screws using a Gamebit 4.5 mm screwdriver.
    • Be cautious not to apply too much pressure to prevent damaging the screws or the GameCube's housing.
  3. How to Repair a Stuck GameCube Eject Button: 手順 3、 2の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 3、 2の画像 2
    • Carefully lift off the top shell of the GameCube housing.
    • Flip over the top housing of the GameCube, making sure the handle is facing away from you.
  4. How to Repair a Stuck GameCube Eject Button: 手順 4、 2の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 4、 2の画像 2
    • Remove the two screws in the bottom left and right corners using a Phillips #00 screwdriver.
    • Have caution while removing the screws from the housing to prevent damage to any components.
  5. How to Repair a Stuck GameCube Eject Button: 手順 5、 2の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 5、 2の画像 2
    • Pull back on the lower section of the spring mechanism until the spring is fully compressed.
    • Lift the spring mechanism out of the GameCube's top housing and place it to the side.
  6. How to Repair a Stuck GameCube Eject Button: 手順 6、 3の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 6、 3の画像 2 How to Repair a Stuck GameCube Eject Button: 手順 6、 3の画像 3
    • Pinch in the two small tabs from the eject button inside the GameCube's top housing.
    • Push the button out on the top-side of the GameCube's top housing.
  7. How to Repair a Stuck GameCube Eject Button: 手順 7、 2の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 7、 2の画像 2
    • Dip one end of a cotton swab in 91% isopropyl alcohol.
    • Wipe away any dust or grime from the spring mechanism with the wet cotton swab.
    • Let the spring mechanism dry for one minute.
    • Use the dry end of a cotton swab to clean up any leftover dust or isopropyl alcohol after the spring mechanism dries.
  8. How to Repair a Stuck GameCube Eject Button: 手順 8、 2の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 8、 2の画像 2
    • Dip one end of a new cotton swab into 91% isopropyl alcohol.
    • Use the new wet cotton swab to clean away any dust or grime on the eject button.
    • Let the eject button dry for one minute.
    • Wipe away any missed dust or any remaining isopropyl alcohol with the dry end of the cotton swab.
  9. How to Repair a Stuck GameCube Eject Button: 手順 9、 3の画像 1 How to Repair a Stuck GameCube Eject Button: 手順 9、 3の画像 2 How to Repair a Stuck GameCube Eject Button: 手順 9、 3の画像 3
    • Push the spring section of the spring mechanism in so that it lays flat along the plastic piece.
    • Place the spring mechanism into the housing with the spring bent down and pressed against the side of the housing.
終わりに
To reassemble your device, perform steps 6 through 1 in reverse.
作成者
3人の作成者と共同で作成されました。
Tanner Hall
メンバー登録日: 10/05/23
169 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 48
過去 30 日: 225
今までの合計 1,186
