メインコンテンツにスキップ
How to Repair a Squier Affinity Stratocaster Guitar Jack
必要な工具と部品
  1. How to Repair a Squier Affinity Stratocaster Guitar Jack, Input Jack: 手順 1、 1の画像 1
    • Test the sound output via amplifier, and then set it to zero.
    • Keeping the amplifier on with the guitar connected to it may produce unpleasant static depending on how loose the jack is. Make sure to turn it off before proceeding.
  2. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 2、 1の画像 1
    • Using the Phillips #3 screwdriver, remove the two 1.2 mm screws that are connected to the plate.
  3. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 3、 1の画像 1
    • Remove the plate without touching the jack.
    • Fixing the jack without removing the plate can cause broken wires. Do not tighten the bolt connecting the jack before taking off the plate.
  4. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 4、 3の画像 1 How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 4、 3の画像 2 How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 4、 3の画像 3
    • Take the jack out of the guitar.
    • Here, you can examine the wires and check for any interior damages.
  5. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 5、 1の画像 1
    • Carefully tighten the outside of the jack using a wrench.
    • If you do not have an adjustable wrench, use an ESP Multi Spanner.
  6. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 6、 1の画像 1
    • Carefully reconnect the plate back on using your screwdriver.
  7. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 7、 1の画像 1
    • Readjust the output settings on your guitar, and plug in your audio cable.
  8. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 8、 1の画像 1
    • Test the tightness of your input jack before plugging your audio cable into your amplifier.
  9. How to Repair a Squier Affinity Stratocaster Guitar Jack: 手順 9、 1の画像 1
    • Plug the guitar into the amplifier to test the audio cable sensitivity and output quality.
終わりに
That is all you need to do to fix your Squier Affinity Stratocaster’s input jack. Now have fun making music!
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Maryam Ahmed
メンバー登録日: 05/12/21
273 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G2, Melo-Thaiss Summer 2021 York University, Team S1-G2, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S1G2
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 120
今までの合計 3,737
