メインコンテンツにスキップ
How to Repair a Snag in Clothing
必要な工具と部品
  1. How to Repair a Snag in Clothing, How to Repair a Snag in Clothing: 手順 1、 1の画像 1
    • Push the snagged thread to back of the piece of clothing.
    • Its easiest to use the eye of the threaded needle to assist in pushing the snagged thread to the inside of the garment.
  2. How to Repair a Snag in Clothing: 手順 2、 1の画像 1
    • Gently dab the fabric with a slightly damp paper towel.
    • This allows the fabric to open itself up while working. Allows the threads to be slightly more elastic when manipulating the snagged thread back into the fabric
  3. How to Repair a Snag in Clothing: 手順 3、 2の画像 1 How to Repair a Snag in Clothing: 手順 3、 2の画像 2
    • Determine what side of the garment you want the repair to be on.
    • Try to draw all the snagged threads to the interior of garment.
  4. How to Repair a Snag in Clothing: 手順 4、 2の画像 1 How to Repair a Snag in Clothing: 手順 4、 2の画像 2
    • Gently pull the fabric apart to loosen the snag.
    • Don't pull the thread too much. Try to incorporate the snagged thread back into the fabric.
  5. How to Repair a Snag in Clothing: 手順 5、 2の画像 1 How to Repair a Snag in Clothing: 手順 5、 2の画像 2
    • Once the snag is minimized, snip the snag on back of the garment with a pair of scissors.
    • Tie a square knot with thread and carefully snip the ends with the scissors.
    • Trim the threads close to knot to minimize any further snagging of the threads.
  6. How to Repair a Snag in Clothing: 手順 6、 2の画像 1 How to Repair a Snag in Clothing: 手順 6、 2の画像 2
    • After work is finished, smooth the garment and hang it to dry.
    • This signals the end of the project. If you've followed all the steps, the snag should be less visible and these steps should stop any further damage, and make the garment wearable again.
終わりに
作成者
1人の作成者と共同作成されました。
Leo Sprankle
メンバー登録日: 01/06/21
133 ポイント
1ガイドが承認済み
チーム
1件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 115
今までの合計 7,993
