メインコンテンツにスキップ
How to Repair a Small Hole in a Spanish Knife Textured Wall
必要な工具と部品
  1. How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 1、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 1、 2の画像 2
    • Remove any debris from the hole in the wall.
  2. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 2、 1の画像 1
    • Scoop some DryDex Spackling on to your plastic taping knife.
  3. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 3、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 3、 2の画像 2
    • Fill the hole with spackle.
  4. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 4、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 4、 2の画像 2
    • Gently move the taping knife over the newly covered hole in multiple directions.
    • This will ensure the spackle completely fills the hole.
    • Let the DryDex Spackle dry.
    • You will know the spackle is dry when it turns from pink to white.
  5. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 5、 1の画像 1
    • Sand the newly spackled area down until the spackle is level with the original wall.
  6. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 6、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 6、 2の画像 2
    • Scoop some All Purpose Joint Compound on to your putty knife.
  7. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 7、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 7、 2の画像 2
    • Smooth the joint compound on the wall, covering the area you want to re-texture.
  8. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 8、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 8、 2の画像 2
    • Gently drag the putty knife through the joint compound to create ridges.
    • Creating ridges is a creative and unique process. You get to decide how close you want the ridges together and at what angle to make the ridges.
    • Let the joint compound completely dry.
    • You will know the Joint Compound is dry when it turns from grey to white.
  9. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 9、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 9、 2の画像 2
    • Mix the paint that you have leftover from the first time you painted the wall.
  10. How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 10、 2の画像 1 How to Repair a Small Hole in a Spanish Knife Textured Wall: 手順 10、 2の画像 2
    • Paint the section of the wall that you re-textured.
    • Paint each ridge.
    • Let the paint completely dry.
終わりに
You’ve successfully spackled, textured, and painted. Your wall is now as good as new!
作成者
1人の作成者と共同作成されました。
Kayla Elder
メンバー登録日: 09/22/21
198 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-4, Boettger Spring 2022 University of North Texas, Team 1-4, Boettger Spring 2022人のメンバー
UNT-BOETTGER-S22S1G4
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 756
