メインコンテンツにスキップ
How to Repair a Shirt Collar
必要な工具と部品
  1. How to Repair a Shirt Collar, How to Repair a Shirt Collar: 手順 1、 1の画像 1
    • Use a seam ripper to completely unstitch the collar.
  2. How to Repair a Shirt Collar: 手順 2、 2の画像 1 How to Repair a Shirt Collar: 手順 2、 2の画像 2
    • Cut a piece of fabric the size of the damaged area, and place it over the interior of the damaged section of the collar.
    • Sewing machines can be dangerous; be sure to always keep your hands clear of the needle's path.
    • Sew the piece of fabric into the collar.
  3. How to Repair a Shirt Collar: 手順 3、 3の画像 1 How to Repair a Shirt Collar: 手順 3、 3の画像 2 How to Repair a Shirt Collar: 手順 3、 3の画像 3
    • Fold your shirt and its altered collar in half, then mark the middle of the pieces with a fabric pencil.
    • This will be handy when stitching the pieces back together.
  4. How to Repair a Shirt Collar: 手順 4、 2の画像 1 How to Repair a Shirt Collar: 手順 4、 2の画像 2
    • Place the fragment of the collar that was altered, the side facing your neck, in the opposite direction.
  5. How to Repair a Shirt Collar: 手順 5、 2の画像 1 How to Repair a Shirt Collar: 手順 5、 2の画像 2
    • Stitch the pieces back together.
    • To simplify the process, add pins beside the path that will be stitched, or just follow the marks of the previous seams that you unstitched in the first step.
  6. How to Repair a Shirt Collar: 手順 6、 1の画像 1
    • Steam irons are extremely hot and can cause burns.
    • Iron the area to settle the new stitching.
終わりに
Enjoy your like-new collar!
作成者
1人の作成者と共同作成されました。
MARLYN H ARNAUD-MAURY
メンバー登録日: 03/18/22
133 ポイント
1ガイドが承認済み
チーム
1件のガイドコメント
It used to be the case when you bought a shirt that it would come with a spare collar and cuff. When the collar started to fray you could take it to your local tailor and they would change the collar for you. While no longer included when you buy a shirt you can repair a shirt collar yourself or if you can't sew there are services like collarreplacement.com that will do this for you.
Vintage - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 63
今までの合計 3,193
