メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Repair a Portable Fan
必要な工具と部品
  1. How to Repair a Portable Fan, How to Repair a Portable Fan: 手順 1、 2の画像 1 How to Repair a Portable Fan, How to Repair a Portable Fan: 手順 1、 2の画像 2
    • Unplug the power cord before beginning.
    • Loosen the 4 phillips screws around the rim and remove the front of the cage
  2. How to Repair a Portable Fan: 手順 2、 1の画像 1
    • Remove the fan blade by loosening the screw on the shaft while pulling up.
    • The screw does not need to be fully removed before the blade will slide free.
  3. How to Repair a Portable Fan: 手順 3、 1の画像 1
    • Remove the wiring cover located above the fan motor.
    • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
  4. How to Repair a Portable Fan: 手順 4、 1の画像 1
    • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
  5. How to Repair a Portable Fan: 手順 5、 1の画像 1
    • Remove the final 2 screws holding the mounting plate to the cage.
  6. How to Repair a Portable Fan: 手順 6、 1の画像 1
    • Carefully pass the motor through the opening at the back of the cage.
  7. How to Repair a Portable Fan: 手順 7、 2の画像 1 How to Repair a Portable Fan: 手順 7、 2の画像 2
    • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
    • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
    • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
  8. How to Repair a Portable Fan: 手順 8、 2の画像 1 How to Repair a Portable Fan: 手順 8、 2の画像 2
    • Clean and lubricate the magnet shaft and mounting brackets
    • Any medium or low viscosity lubricant will do.
終わりに
To reassemble your device, follow these steps in reverse order.
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Isaac MacMillan
メンバー登録日: 10/02/17
227 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team S5-G11, Galliah Fall 2017 Michigan Tech, Team S5-G11, Galliah Fall 2017人のメンバー
MTU-GALLIAH-F17S5G11
2 メンバー
2のガイドは作成済み
4件のガイドコメント
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - 返信
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Clark Nova - 返信
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
adewale ogunbona - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 34
過去 30 日: 141
今までの合計 21,597
