メインコンテンツにスキップ
How to Repair a Missing Crochet Stitch
必要な工具と部品
  1. How to Repair a Missing Crochet Stitch, How to Repair a Missing Crochet Stitch: 手順 1、 1の画像 1
    • Identify where the repair is needed. Locate where the missing stitch should be.
  2. How to Repair a Missing Crochet Stitch: 手順 2、 1の画像 1
    • Use the crochet hook to hook through the base stitch, (where the missing stitch should have been located), from front to back.
  3. How to Repair a Missing Crochet Stitch: 手順 3、 1の画像 1
    • Create a slip knot with the yarn. Leaving about a 3 inch tail at the end to weave in later.
  4. How to Repair a Missing Crochet Stitch: 手順 4、 1の画像 1
    • Loop the slip knot loop over the hook, and pull the yarn through the base stitch
  5. How to Repair a Missing Crochet Stitch: 手順 5、 1の画像 1
    • Chain stitch the amount of stitches that the missing stitch should be plus one.
    • So if the missing stitch is a single crochet stitch, chain stitch two stitches, if the missing stitch is a double crochet stitch, chain stitch three stitches, and so on.
  6. How to Repair a Missing Crochet Stitch: 手順 6、 1の画像 1
    • Remove the crochet hook and knot the remaining loop. Cut off the yarn leaving another 3 inch tail.
  7. How to Repair a Missing Crochet Stitch: 手順 7、 1の画像 1
    • Thread the darning needle with one of the 3 inch tails. It does not matter which one you choose.
    • Caution: Needle is sharp and should be handled carefully to avoid injury.
  8. How to Repair a Missing Crochet Stitch: 手順 8、 1の画像 1
    • Begin to weave the tail into the surrounding stitches from front to back.
    • Make sure to split the yarn when weaving, for a more seamless look.
  9. How to Repair a Missing Crochet Stitch: 手順 9、 1の画像 1
    • After fully weaving one tail, cut off any excess, and begin weaving the next. Repeating Step 7 through 8.
終わりに
作成者
1人の作成者と共同作成されました。
Rylie Vallo
メンバー登録日: 10/11/20
179 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S1-G16, Johnson Fall 2020 Linn Benton Community College, Team S1-G16, Johnson Fall 2020人のメンバー
LBCC-JOHNSON-F20S1G16
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 149
今までの合計 6,960
