はじめに
Have you noticed a snag or loose thread in one of your embroidery pieces? Don't get rid of it! This step-by-step guide will help you repair it. It is such an easy fix that only takes a few steps using the right tools.
必要な工具と部品
Gather all the necessary materials for your fix following these guidelines:
Pick the proper embroidery needle size. Lightweight fabrics can use a smaller needle, while heavyweight fabrics will need a larger needle.
Ensure that you pick a color of embroidery floss that matches the color of the thread you are trying to fix.
If using a lightweight fabric (e.g. cotton), use an embroidery hoop to stabilize the fabric.
To use fabric glue, apply 1-2 drops everywhere that there is embroidery on the back of the fabric. Allow this to dry for at least 5 minutes.
If using a steamer, follow the instructions to turn it on for your particular model. Run the steamer over the back of the fabric two times. This will make the stitches taut.
