メインコンテンツにスキップ
How to Repair a Jammed 2007 GMC Envoy Tailgate
必要な工具と部品
  1. How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: 手順 1、 3の画像 1 How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: 手順 1、 3の画像 2 How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: 手順 1、 3の画像 3
    • Use the flat head screwdriver to pry off the small round access panel on the interior of the tailgate.
  2. How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 2、 2の画像 1 How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 2、 2の画像 2
    • Look through the opening and stick your flat head screwdriver underneath this metal arm.
    • Force the arm up. It should stay raised when you pull the screwdriver out.
    • DO NOT USE YOUR FINGER, there is risk of pinching and injury if you do not use the specified tools.
  3. How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 3、 3の画像 1 How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 3、 3の画像 2 How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 3、 3の画像 3
    • Use the flat head screwdriver to push this second lever to the right as far as it will go or until it clicks.
  4. How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 4、 2の画像 1 How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 4、 2の画像 2
    • The tailgate is now unlatched. Open it from the outside.
    • Replace the access panel.
    • If the tailgate will still not open, you most likely did not push the second lever over far enough. Repeat Step 3.
  5. How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 5、 2の画像 1 How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 5、 2の画像 2
    • Inspect the latch bracket's horizontal and vertical bars for dents, warping, and corrosion.
    • If there are no physical defects visible, clean any rust and corrosion and test the tailgate. If it still jams, repeat Steps 1-4 and move on to Step 6.
  6. How to Repair a Jammed 2007 GMC Envoy Tailgate: 手順 6、 1の画像 1
    • Use the 40 Torx screwdriver to remove the two T40 63.5 mm screws that secure the latch bracket.
    • Remove the latch from the vehicle.
終わりに
To reassemble your device, follow these steps in reverse order.
作成者
2人の作成者と共同で作成されました。
Amanda Smith
メンバー登録日: 08/25/20
254 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 27
過去 30 日: 90
今までの合計 3,368
