メインコンテンツにスキップ
How to Repair a Hole on the Shoe Sole
必要な工具と部品
  1. How to Repair a Hole on the Shoe Sole, How to Repair a Hole on the Shoe Sole: 手順 1、 3の画像 1 How to Repair a Hole on the Shoe Sole, How to Repair a Hole on the Shoe Sole: 手順 1、 3の画像 2 How to Repair a Hole on the Shoe Sole, How to Repair a Hole on the Shoe Sole: 手順 1、 3の画像 3
    • Scrape off any extra material near the area of the hole that is not part of the outsole of the shoe.
    • Clean the outsole with a wet paper towel.
    • Clean and dry the outsole with a paper towel before starting.
  2. How to Repair a Hole on the Shoe Sole: 手順 2、 3の画像 1 How to Repair a Hole on the Shoe Sole: 手順 2、 3の画像 2 How to Repair a Hole on the Shoe Sole: 手順 2、 3の画像 3
    • Use the 120 grit sandpaper to roughen the edges of the hole on the outsole.
    • This helps the shoe goo adhere more readily to the outsole.
  3. How to Repair a Hole on the Shoe Sole: 手順 3、 3の画像 1 How to Repair a Hole on the Shoe Sole: 手順 3、 3の画像 2 How to Repair a Hole on the Shoe Sole: 手順 3、 3の画像 3
    • Pull the insole out of the shoe.
    • Apply duct tape inside the shoe (on the other side of the hole).
    • Make sure the duct tape covers up the entire hole, so there will be no shoe goo going through the sole into the shoe.
    • For holes that ripped through the shoe sole and to the inside of the shoe, this step is very important.
  4. How to Repair a Hole on the Shoe Sole: 手順 4、 2の画像 1 How to Repair a Hole on the Shoe Sole: 手順 4、 2の画像 2
    • Apply the shoe goo to fill up the hole on the outsole.
    • Apply enough shoe goo to cover up all of the areas of the hole.
  5. How to Repair a Hole on the Shoe Sole: 手順 5、 3の画像 1 How to Repair a Hole on the Shoe Sole: 手順 5、 3の画像 2 How to Repair a Hole on the Shoe Sole: 手順 5、 3の画像 3
    • Spread the shoe goo evenly with an ice cube to cover up any uncovered area.
    • The shoe goo will not stick to the ice cube, and you will be able to easily spread the shoe goo. The coldness of the ice also helps the shoe goo set in place.
  6. How to Repair a Hole on the Shoe Sole: 手順 6、 1の画像 1
    • Let the shoe sit for 24 hours for the shoe goo to dry.
    • In this period, do not let any objects come into contact with the glue.
  7. How to Repair a Hole on the Shoe Sole: 手順 7、 3の画像 1 How to Repair a Hole on the Shoe Sole: 手順 7、 3の画像 2 How to Repair a Hole on the Shoe Sole: 手順 7、 3の画像 3
    • After 24 hours, remove the duct tape from the shoe.
    • Place the insole back into the shoe.
  8. How to Repair a Hole on the Shoe Sole: 手順 8、 3の画像 1 How to Repair a Hole on the Shoe Sole: 手順 8、 3の画像 2 How to Repair a Hole on the Shoe Sole: 手順 8、 3の画像 3
    • Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth.
終わりに
Now you can walk again!
30 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Wei Zeng
メンバー登録日: 09/29/15
1,028 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G4
5 メンバー
16のガイドは作成済み
10 件のコメント
Excellent - thank you
Amanda Bowdler - 返信
I used shoe goo on part of the sole that touch the concrete and over about a weeks time it eventually just fell out.
kimdelee - 返信
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
blackwidow - 返信
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
Olga rodriguez - 返信
heel patch has to extend a considerable length past the actual part to repair (preferably into any grooves) to reduce edges of the patch from peeling and falling off.
Doug - 返信
コメントを追加
統計データ:
過去 24時間: 155
過去 7 日: 1,021
過去 30 日: 5,378
今までの合計 396,190
