メインコンテンツにスキップ
How to Repair a Hole in an Inflatable Floatie
必要な工具と部品
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 手順 1、 3の画像 1 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 手順 1、 3の画像 2 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 手順 1、 3の画像 3
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: 手順 2、 2の画像 1 How to Repair a Hole in an Inflatable Floatie: 手順 2、 2の画像 2
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: 手順 3、 3の画像 1 How to Repair a Hole in an Inflatable Floatie: 手順 3、 3の画像 2 How to Repair a Hole in an Inflatable Floatie: 手順 3、 3の画像 3
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: 手順 4、 3の画像 1 How to Repair a Hole in an Inflatable Floatie: 手順 4、 3の画像 2 How to Repair a Hole in an Inflatable Floatie: 手順 4、 3の画像 3
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: 手順 5、 3の画像 1 How to Repair a Hole in an Inflatable Floatie: 手順 5、 3の画像 2 How to Repair a Hole in an Inflatable Floatie: 手順 5、 3の画像 3
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: 手順 6、 2の画像 1 How to Repair a Hole in an Inflatable Floatie: 手順 6、 2の画像 2
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
終わりに
Enjoy your renewed floatie!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Selena Barnhart
メンバー登録日: 03/01/23
166 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 60-2, Watkins Spring 2023 Austin Community College, Team 60-2, Watkins Spring 2023人のメンバー
AUSTINCC-WATKINS-S23S60G2
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 183
