メインコンテンツにスキップ
How to Repair a Hole in the Wall Using Spackle
必要な工具と部品
  1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: 手順 1、 3の画像 1 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: 手順 1、 3の画像 2 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: 手順 1、 3の画像 3
    • Prepare the damaged surface by cleaning and removing all dust and debris.
    • If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
  2. How to Repair a Hole in  the Wall Using Spackle: 手順 2、 3の画像 1 How to Repair a Hole in  the Wall Using Spackle: 手順 2、 3の画像 2 How to Repair a Hole in  the Wall Using Spackle: 手順 2、 3の画像 3
    • Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
    • Press patch firmly to ensure a strong bond to the wall.
  3. How to Repair a Hole in  the Wall Using Spackle: 手順 3、 3の画像 1 How to Repair a Hole in  the Wall Using Spackle: 手順 3、 3の画像 2 How to Repair a Hole in  the Wall Using Spackle: 手順 3、 3の画像 3
    • Open container and mix spackling compound before applying.
    • Mix thoroughly to have a smooth application.
  4. How to Repair a Hole in  the Wall Using Spackle: 手順 4、 3の画像 1 How to Repair a Hole in  the Wall Using Spackle: 手順 4、 3の画像 2 How to Repair a Hole in  the Wall Using Spackle: 手順 4、 3の画像 3
    • Use the putty knife to spread spackling compound evenly over the adhesive patch.
    • Spread the spackling mixture beyond the area intended to cover.
    • Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
  5. How to Repair a Hole in  the Wall Using Spackle: 手順 5、 2の画像 1 How to Repair a Hole in  the Wall Using Spackle: 手順 5、 2の画像 2
    • Allow the compound to dry completely before moving to the last step.
    • Depending on the hole's size and thickness of the layers applied, it might take a while to dry.
  6. How to Repair a Hole in  the Wall Using Spackle: 手順 6、 3の画像 1 How to Repair a Hole in  the Wall Using Spackle: 手順 6、 3の画像 2 How to Repair a Hole in  the Wall Using Spackle: 手順 6、 3の画像 3
    • Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
    • Smooth out any bumps on the surface.
    • Do not sand down to mesh patch.
    • Once the surface is smooth, paint, wallpaper, or apply any texture desire.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kerticia Miller
メンバー登録日: 01/17/21
160 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G17, Melo-Thaiss Winter 2021 York University, Team S1-G17, Melo-Thaiss Winter 2021人のメンバー
YORK-MELO-THAISS-W21S1G17
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 29
過去 30 日: 138
今までの合計 2,750
