メインコンテンツにスキップ
How to Repair a Glitchy TI-83 Plus Screen
必要な工具と部品
  1. How to Repair a Glitchy TI-83 Plus Screen, How to Repair a Glitchy TI-83 Plus Screen: 手順 1、 2の画像 1 How to Repair a Glitchy TI-83 Plus Screen, How to Repair a Glitchy TI-83 Plus Screen: 手順 1、 2の画像 2
    • Remove the battery cover and the batteries that come with it.
  2. How to Repair a Glitchy TI-83 Plus Screen: 手順 2、 1の画像 1
    • Remove the 5 mm Phillips #00 screw holding the backup battery cover.
    • Remove the backup battery cover
  3. How to Repair a Glitchy TI-83 Plus Screen: 手順 3、 1の画像 1
    • Remove the backup battery by using the plastic opening tool. Pry it on the left of the battery where their is an opening to stick the tool into.
  4. How to Repair a Glitchy TI-83 Plus Screen: 手順 4、 1の画像 1
    • Unscrew the six 7.5 mm T6 screws on the back shell. You will need to use a screwdriver with a long and skinny head
  5. How to Repair a Glitchy TI-83 Plus Screen: 手順 5、 2の画像 1 How to Repair a Glitchy TI-83 Plus Screen: 手順 5、 2の画像 2
    • Pry back shell off by Inserting the plastic opening tool in the track where the protective cover slides into and pry the halves of the shell apart.
  6. How to Repair a Glitchy TI-83 Plus Screen: 手順 6、 2の画像 1 How to Repair a Glitchy TI-83 Plus Screen: 手順 6、 2の画像 2
    • Remove the protective sheet from the mother board by unscrewing the two 1 mm Phillips #00 screws.
  7. How to Repair a Glitchy TI-83 Plus Screen: 手順 7、 3の画像 1 How to Repair a Glitchy TI-83 Plus Screen: 手順 7、 3の画像 2 How to Repair a Glitchy TI-83 Plus Screen: 手順 7、 3の画像 3
    • Set your heat gun to the lowest setting(around 150 degrees)
    • If you are missing lines on the screen, aim at the top ribbon cables and heat the cable evenly for about 5 seconds.
    • Then heat and apply pressure using the plastic opening tool for about 5-10 seconds, applying pressure to different sections of the ribbon cable within that timeframe.
    • Continue to apply pressure throughout the ribbons.
    • If the screen is Glitchy, do the same for the bottom ribbon cable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Simon Rafael
メンバー登録日: 03/20/24
177 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 1-66, Harris Spring 2024 CSU Los Angeles, Team 1-66, Harris Spring 2024人のメンバー
CSULA-HARRIS-S24S1G66
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 57
今までの合計 1,080
