メインコンテンツにスキップ
How to Repair a Damaged Steelcase Cachet Chair Armrest
必要な工具と部品
  1. How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 1、 3の画像 1 How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 1、 3の画像 2 How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 1、 3の画像 3
    • Use an iFixit Opening Tool to remove the broken piece from your cracked armrest.
    • Avoid the jagged edges of plastic as they are sharp and could cut or scrape the skin.
  2. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 2、 2の画像 1 How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 2、 2の画像 2
    • Use sandpaper to lightly sand the edges of the broken piece of arm rest.
    • Remove any remaining debris from the armrest.
  3. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 3、 2の画像 1 How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 3、 2の画像 2
    • Wear gloves! The putty is toxic!
    • Cut or pull off a small section of putty.
    • Knead the putty in your hands for 30-60 seconds until it is a uniform color.
  4. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 4、 1の画像 1
    • Work quickly! The putty will begin to harden in 5 minutes!
    • Apply a small amount of putty on the inside of the hollow space of the armrest.
    • The putty will act as a support for the broken piece.
    • Repeat Step 3 to use as many pieces of putty as needed.
  5. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 5、 1の画像 1
    • Apply putty along the edges of the broken piece.
  6. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 6、 2の画像 1 How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 6、 2の画像 2
    • Set the broken piece back onto the armrest.
    • Try to make the broken piece level with the rest of the armrest, as this will make Steps 7 & 8 easier.
    • Let the putty dry for about 10 minutes.
  7. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 7、 2の画像 1 How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 7、 2の画像 2
    • Apply the plastic putty over the broken piece.
    • Press putty into any remaining empty spaces.
    • Repeat Step 3 as many times as needed.
    • Let the putty dry for 10 minutes in between applications.
  8. How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 8、 2の画像 1 How to Repair a Damaged Steelcase Cachet Chair Armrest: 手順 8、 2の画像 2
    • Sand down the putty covering to make the surface smooth and level with the armrest.
    • Paint-match the color of the chair and paint over the putty for a cosmetically seamless result.
ゴール
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Henry Xu
メンバー登録日: 04/26/24
169 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 4-5, Whithaus Spring 2024 UC Davis, Team 4-5, Whithaus Spring 2024人のメンバー
UCD-WHITHAUS-S24S4G5
3 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 28
今までの合計 518
