メインコンテンツにスキップ
How to Repair a Crack on a Vittorazi Moster Exhaust
必要な工具と部品
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 1、 3の画像 1 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 1、 3の画像 2 How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 1、 3の画像 3
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 5、 2の画像 1 How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 5、 2の画像 2
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 6、 1の画像 1
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 7、 1の画像 1
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 8、 2の画像 1 How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 8、 2の画像 2
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 9、 2の画像 1 How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 9、 2の画像 2
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 10、 2の画像 1 How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 10、 2の画像 2
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: 手順 11、 1の画像 1
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
ゴール
作成者
5人の作成者と共同で作成されました。
Darrell Gonzalez
メンバー登録日: 09/20/21
207 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 17
今までの合計 1,066
