メインコンテンツにスキップ
How to Repair a Cooluli Classic-4L That Won't Cool
必要な工具と部品
  1. How to Repair a Cooluli Classic-4L That Won't Cool, How to Repair a Cooluli Classic-4L That Won't Cool: 手順 1、 3の画像 1 How to Repair a Cooluli Classic-4L That Won't Cool, How to Repair a Cooluli Classic-4L That Won't Cool: 手順 1、 3の画像 2 How to Repair a Cooluli Classic-4L That Won't Cool, How to Repair a Cooluli Classic-4L That Won't Cool: 手順 1、 3の画像 3
    • Remove the plastic basket and tray from the inside of the refrigerator by sliding them out of the holders.
    • Remove any and all products from inside of the refrigerator.
    • If you have any perishable products in your Cooluli Classic-4L, temporarily store them in another refrigerator.
  2. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 2、 1の画像 1
    • Place the refrigerator on a flat surface with a towel beneath it to catch any water that drains out during defrosting.
  3. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 3、 1の画像 1
    • Leave the refrigerator overnight with the door open to allow the inside to defrost.
  4. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 4、 2の画像 1 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 4、 2の画像 2
    • After the refrigerator has defrosted overnight, clean the inside of the refrigerator with warm water and liquid soap.
    • Dry thoroughly with a soft cloth or paper towels.
    • If there is still ice on the inside of the refrigerator, wipe away with a warm, damp cloth.
    • Do not chip away at the ice with a hard object, as you may damage the plastic lining of the inside of the refrigerator.
  5. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 5、 3の画像 1 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 5、 3の画像 2 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 5、 3の画像 3
    • Use a Phillips #000 screwdriver to remove the six 4 mm screws from the plastic back cover of the refrigerator.
    • Gently move the cover away from the back of the refrigerator once all of the screws are removed.
  6. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 6、 3の画像 1 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 6、 3の画像 2 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 6、 3の画像 3
    • Wipe away any dust and dirt from the ventilation fan with a dry cloth or paper towel.
    • You can use a cotton swab to clean the smaller corners of the fan.
  7. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 7、 3の画像 1 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 7、 3の画像 2 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 7、 3の画像 3
    • Replace the back cover of the refrigerator.
    • Place the six 4 mm screws in the holes of the back cover, then screw in with the Phillips #000 screwdriver.
  8. How to Repair a Cooluli Classic-4L That Won't Cool: 手順 8、 3の画像 1 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 8、 3の画像 2 How to Repair a Cooluli Classic-4L That Won't Cool: 手順 8、 3の画像 3
    • Put the removable tray and basket back into the refrigerator.
    • Plug your refrigerator into an external power source.
    • Place your products back into the refrigerator.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Olivia Arredondo
メンバー登録日: 10/09/21
238 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-3, Friess Fall 2021 University of North Texas, Team 1-3, Friess Fall 2021人のメンバー
UNT-FRIESS-F21S1G3
1 メンバー
2のガイドは作成済み
14 件のコメント
What if it has stopped cooling but there is no ice buildup??
Janell Gill - 返信
Mine doesn't have frosting either but all of a sudden it stopped cooling. The air vent is not blocked or anything. I had it for a year and a half working just fine and all of a sudden it stopped working. And now the green light blinks when I turn it on.
Barbara Pažur -
Same. Just stopped working. Great lil fridge too.
Green light is not working or on at all. Was a little dust buildup but nothing overwhelming.
Might be done.
J Dog -
Mine cools but sounds like a jet engine taking off; how to fix?
KR4i7 - 返信
I have a problem with my vanity planet fridge not making a tan noise , it stopped cooling I cleaned it today and put it back and now the fan is very very quiet what do I do?
Stefani Ivanova - 返信
コメントを追加
統計データ:
過去 24時間: 33
過去 7 日: 207
過去 30 日: 1,069
今までの合計 32,456
