メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Repair a Broken Zipper With Soap
必要な工具と部品
    1. How to Repair a Broken Zipper With Soap, How to Repair a Broken Zipper With Soap: 手順 1、 1の画像 1
      • Look at the zipper to check if the fabric is stuck in the track or if the zipper is the problem before you begin the fix.
      FixBotに聞いてみる
      コメントを追加
    2. How to Repair a Broken Zipper With Soap: 手順 2、 1の画像 1
      • Try to zip the zipper.
      • The fabric may block the zipper but it's worth a try. Sometimes, a final attempt will fix the issue.
      • Once you confirm it does not zip, proceed to the next step.
      FixBotに聞いてみる
      コメントを追加
    3. How to Repair a Broken Zipper With Soap: 手順 3、 2の画像 1 How to Repair a Broken Zipper With Soap: 手順 3、 2の画像 2
      • Slide the zipper down to its base or the starting point of the zipper track.
      • Avoid forcing the zipper past the point where it's stuck, as this may make restoring full functionality more challenging.
      • Pull both sides of the fabric sides away from the zipper track.
      • This will ensure no fabric is near the track. Pulling the fabric away may restore functionality if it has gotten stuck in the track. You may need a friend for this so you can work on the zipper in the next step.
      FixBotに聞いてみる
      コメントを追加
    4. How to Repair a Broken Zipper With Soap: 手順 4、 1の画像 1
      • Hold the sides of the fabric to pull it away from the midline of the zipper track and try to zip the zipper again.
      FixBotに聞いてみる
      コメントを追加
    5. How to Repair a Broken Zipper With Soap: 手順 5、 1の画像 1
      • Here is where our mission splits into two.
      • If you know the zipper is getting caught, keep working it until it doesn't get stuck.
      • If the side fabric is fine after you move it, then the issue is with the zipper.
      • Check the track and nearby areas for any flaws. Look for scuffs and skewed zippers.
      • This may show the problem with the zipper track.
      FixBotに聞いてみる
      コメントを追加
    6. How to Repair a Broken Zipper With Soap: 手順 6、 1の画像 1
      • Return the zipper pull to its starting point without jamming further.
      • Rub the bar of soap on the zipper track that is stuck.
      • You should see quite a bit of soap, but not so much that you can't see the zipper.
      FixBotに聞いてみる
      コメントを追加
    7. How to Repair a Broken Zipper With Soap: 手順 7、 1の画像 1
      • Begin unzipping and zipping as far as you can.
      • Repeat steps 1-7 if the first time did not work or you have more of the zipper to cover.
      • Once the zipper is moving smoothly up and down the track, clean the zipper if too much soap has accumulated.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
hayleecates
メンバー登録日: 10/16/24
169 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 29-3, Watkins Fall 2024 Austin Community College, Team 29-3, Watkins Fall 2024人のメンバー
AUSTINCC-WATKINS-F24S29G3
1 メンバー
8のガイドは作成済み
1件のガイドコメント
A pair of pliers that I believe are called Rebar pliers is easier to use when tightening the glider. That is because the material often is quite thick and a straight nosed plier is held apart by it if the glider is not very big, on the side away from the opening. On the open side it is no problem.
Susanne from Denmark - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 72
今までの合計 880
