メインコンテンツにスキップ
How to Repair a Broken Kitchen Faucet Pull-out Spray Head
必要な工具と部品
  1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: 手順 1、 2の画像 1 How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: 手順 1、 2の画像 2
    • Located underneath the sink is the water-control valve.
    • Shut off the water supply by turning the water-control valve.
    • Not all water control values are the same so some nozzles may vary.
  2. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 2、 3の画像 1 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 2、 3の画像 2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 2、 3の画像 3
    • Pull on the kitchen spray head nozzle to reveal the connected hose.
    • Unscrew the kitchen faucet spray head nozzle counterclockwise off of the hose assembly.
  3. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 3、 2の画像 1 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 3、 2の画像 2
    • Remove the rubber gasket from the hose to reveal the c-clip.
    • Remove the c-clip that is located on the pull-out sprayer connection point with a small flat head screwdriver.
    • Do not discard the gasket. It can be reused unless damaged.
  4. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 4、 2の画像 1 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 4、 2の画像 2
    • Pull on the sink faucet spray head from above the sink to find the main hose connection point to the water line located underneath the sink.
    • Unscrew the hose from the main faucet’s water line connection point.
    • A wrench may be necessary in order to loosen the nut.
    • Remove the hose from the sink sprayer location.
    • Connect the new hose by pressing it into the connection point. Then screw hose back on clockwise.
    • A wrench may be necessary in order to secure the end of the hose to the nut.
  5. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 手順 5、 1の画像 1
    • Apply plumber's tape to the male threads on the new sink sprayer head to avoid leakage.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jodi Wright
メンバー登録日: 02/23/16
158 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team 26-2, Rauch Spring 2016 Texas Tech, Team 26-2, Rauch Spring 2016人のメンバー
TTU-RAUCH-S16S26G2
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 66
今までの合計 13,710
