メインコンテンツにスキップ
How to Repair a Broken Cabinet
必要な工具と部品
  1. How to Repair a Broken Cabinet, How to Repair a Broken Cabinet: 手順 1、 1の画像 1
    • This is the broken dresser drawer, duct tape & 5 minute 2 part wood epoxy.
  2. How to Repair a Broken Cabinet: 手順 2、 2の画像 1 How to Repair a Broken Cabinet: 手順 2、 2の画像 2
    • Take a piece of duct tape and put it on both sides for extra bonding support. Only put the tape on the bigger part of the dresser door for now. You will attach the other side with tape in a later step.
  3. How to Repair a Broken Cabinet: 手順 3、 3の画像 1 How to Repair a Broken Cabinet: 手順 3、 3の画像 2 How to Repair a Broken Cabinet: 手順 3、 3の画像 3
    • This is a 5 minute quick setting 2 part wood epoxy. Take the top off the epoxy. Connect the syringe tip and lock it in place. Press the plunger so you can fill the needle tip with epoxy.
  4. How to Repair a Broken Cabinet: 手順 4、 3の画像 1 How to Repair a Broken Cabinet: 手順 4、 3の画像 2 How to Repair a Broken Cabinet: 手順 4、 3の画像 3
    • Run a thick bead of epoxy on the inside rim of the cabinet from one end to the other.
  5. How to Repair a Broken Cabinet: 手順 5、 1の画像 1
    • Run a thick bead of epoxy on the inside rim of the smaller piece of cabinet door.
  6. How to Repair a Broken Cabinet: 手順 6、 3の画像 1 How to Repair a Broken Cabinet: 手順 6、 3の画像 2 How to Repair a Broken Cabinet: 手順 6、 3の画像 3
    • Attach and align the smaller cabinet door section to the bigger cabinet door section. Press them firmly together and apply the duct tape on both ends for bonding support.
  7. How to Repair a Broken Cabinet: 手順 7、 3の画像 1 How to Repair a Broken Cabinet: 手順 7、 3の画像 2 How to Repair a Broken Cabinet: 手順 7、 3の画像 3
    • Flip door over to front side and tape both ends of the cabinet. This will add more support while it is drying.
  8. How to Repair a Broken Cabinet: 手順 8、 3の画像 1 How to Repair a Broken Cabinet: 手順 8、 3の画像 2 How to Repair a Broken Cabinet: 手順 8、 3の画像 3
    • After at least 15 minutes you can pull tape off completely and wipe away any excess epoxy. It is now finished and ready to be re-installed back to the cabinet.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Calvesta Walk
メンバー登録日: 02/07/16
254 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 5-8, Prince Winter 2016 Pasco Hernando, Team 5-8, Prince Winter 2016人のメンバー
PHSC-PRINCE-W16S5G8
1 メンバー
1のガイドは作成済み
コメント 1 件
Lifesaver brother!
Doug Gray - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 39
過去 30 日: 237
今までの合計 22,758
