はじめに
Everyone has that favorite bra that provides great support, perfect shaping, and full coverage. However, years of use, repeated washing, and constant chafing can lead to a bra underwire poking its way out of its cloth tubing. Exposed bra underwires can potentially injure the wearer and cause the bra to lose its support and structure. Happily, exposed bra underwires can easily be fixed in a matter of minutes, needing nothing more than a needle, colored thread of your choice, and a pair of scissors. Having good lighting while performing this repair is recommended.
必要な工具と部品
Push the underwire into the hole until it is no longer visible.
Use a whip stitch to mend the tear.
Pull the needle through the fabric until the knot at the end of the thread approaches the incision.
On the opposite side, insert the needle again at a point just after the first incision and pull it through the fabric.
Continue this pattern two or three stitches below the tear.
Wear your bra a few times to make sure the underwire doesn't force its way out again. If it does, use tighter stitches and sew them a little closer together.
