メインコンテンツにスキップ
How to Repair Your Torn Sleeping Bag
必要な工具と部品
  1. How to Repair Your Torn  Sleeping Bag, How to Repair Your Torn  Sleeping Bag: 手順 1、 1の画像 1
    • Push any stuffing/down filling back into the hole.
    • You can use your finger, but depending on the size of the hole you may want to use a smaller object so that it doesn't tear further.
  2. How to Repair Your Torn  Sleeping Bag: 手順 2、 3の画像 1 How to Repair Your Torn  Sleeping Bag: 手順 2、 3の画像 2 How to Repair Your Torn  Sleeping Bag: 手順 2、 3の画像 3
    • Take your roll of duct tape and cut off a small amount (about as long as the tear)
  3. How to Repair Your Torn  Sleeping Bag: 手順 3、 1の画像 1
    • Fold the edges of the tear back towards the stuffing so that you create a clean edge with no fraying.
    • This makes it easier to apply the duct tape.
  4. How to Repair Your Torn  Sleeping Bag: 手順 4、 1の画像 1
    • Apply the duct tape to each half of the tear and fold it under, creating a cuff/edge of duct tape
    • This will allow you to sew the fabric without tearing it.
  5. How to Repair Your Torn  Sleeping Bag: 手順 5、 1の画像 1
    • Take a small needle and thread it with thread of similar color to the sleeping bag material (can be any color but a similar one makes the fix less noticeable)
    • Working with needles can be dangerous.
  6. How to Repair Your Torn  Sleeping Bag: 手順 6、 3の画像 1 How to Repair Your Torn  Sleeping Bag: 手順 6、 3の画像 2 How to Repair Your Torn  Sleeping Bag: 手順 6、 3の画像 3
    • Push the two pieces of duct tape together and use the needle and thread to sew them together with a whip stitch.
  7. How to Repair Your Torn  Sleeping Bag: 手順 7、 3の画像 1 How to Repair Your Torn  Sleeping Bag: 手順 7、 3の画像 2 How to Repair Your Torn  Sleeping Bag: 手順 7、 3の画像 3
    • Pull the thread tight when you reach the end of the tape and tie a knot in the string
    • Cut off any remaining thread.
  8. How to Repair Your Torn  Sleeping Bag: 手順 8、 2の画像 1 How to Repair Your Torn  Sleeping Bag: 手順 8、 2の画像 2
    • Cut off any remaining duct tape.
    • Be wary of a sticky residue that may be left behind from the duct tape if pulled off to remove excess
    • Enjoy your newly patched sleeping bag!
ゴール
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Michelle Stovall
メンバー登録日: 09/29/15
128 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-4, Green Fall 2015 Cal Poly, Team 10-4, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 33
今までの合計 6,244
