メインコンテンツにスキップ
How to Repair Water Damage Under Your Sink
必要な工具と部品
  1. How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 手順 1、 3の画像 1 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 手順 1、 3の画像 2 How to Repair Water Damage Under Your Sink, How to Repair Water Damage Under Your Sink: 手順 1、 3の画像 3
    • Remove all items from under your sink.
    • Test for water leaks by gently pressing the cabinet with your fingers and seeing if it's wet and by looking for drips from the sink.
    • Clean the cabinet using a sponge or cloth with a cleaner or disinfectant of your choice.
  2. How to Repair Water Damage Under Your Sink: 手順 2、 3の画像 1 How to Repair Water Damage Under Your Sink: 手順 2、 3の画像 2 How to Repair Water Damage Under Your Sink: 手順 2、 3の画像 3
    • Use work gloves to sand the cabinet.
    • Use 100-grit sandpaper to sand the interior of the cabinets using a circular motion.
    • Sand until you can move your hand across the cabinet, and it feels smooth.
    • Clean the sand dust from the cabinet with a damp cloth or sponge.
  3. How to Repair Water Damage Under Your Sink: 手順 3、 3の画像 1 How to Repair Water Damage Under Your Sink: 手順 3、 3の画像 2 How to Repair Water Damage Under Your Sink: 手順 3、 3の画像 3
    • Apply wood filler with a paint tool making sure you don't apply too much of the filler.
    • You want the layer of filler to be smooth for when you paint over it later.
    • Use painter's tape to mark the areas that you don't want paint on.
  4. How to Repair Water Damage Under Your Sink: 手順 4、 3の画像 1 How to Repair Water Damage Under Your Sink: 手順 4、 3の画像 2 How to Repair Water Damage Under Your Sink: 手順 4、 3の画像 3
    • Use a caulking gun to seal the edges of the base. Gently press down on the applicator and follow the perimeter of the cabinet.
    • Use your finger to wipe all excess caulk off.
    • Let it dry for 30 minutes.
  5. How to Repair Water Damage Under Your Sink: 手順 5、 3の画像 1 How to Repair Water Damage Under Your Sink: 手順 5、 3の画像 2 How to Repair Water Damage Under Your Sink: 手順 5、 3の画像 3
    • Use an angle brush to paint all the edges with primer.
    • Use a roller to paint the rest of the cabinet with primer.
    • Let it dry for 1 hour or until it is completely dry.
  6. How to Repair Water Damage Under Your Sink: 手順 6、 3の画像 1 How to Repair Water Damage Under Your Sink: 手順 6、 3の画像 2 How to Repair Water Damage Under Your Sink: 手順 6、 3の画像 3
    • Use an angle brush to paint all the edges with the paint of your choice.
    • Use the roller to complete painting the cabinet.
    • Let the paint dry.
    • Place your items back under the sink.
終わりに
Now, you've got a good-as-new cabinet! You can reapply as needed if paint chips or dulls.
作成者
2人の作成者と共同で作成されました。
Chelsea Trevino
メンバー登録日: 09/24/23
136 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 1-12, Watkins Fall 2023 Austin Community College, Team 1-12, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S1G12
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 31
過去 30 日: 137
今までの合計 1,986
