はじめに
After no clear guide on options for fixing this common issue, this was created.
パーツ
パーツは必要ありません。
  1. First, check fuses and see if any are out. At times other fuses and issues trip more issues. If all good, check circuit breakers located under dash on drivers side.
    • First, check fuses and see if any are out. At times other fuses and issues trip more issues.
    • If all good, check circuit breakers located under dash on drivers side.
    • Circuit breakers labeled: (Power) 30A and (Automatic Shoulder Belt) 30A may be tripped. This is a simple fix. Just by sticking a toothpick or needle in hole located on circuit breaker (see 2nd photo). If it clicks, it may have been tripped and you journey may end here, if not then continue.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. If you were like me, it was not as simple as a fuse or breaker. You may need to check your wires coming from the switches on the door, specifically in the door jam. Due to age and wear, you may have a tear (mix-tape dropping soon). OR like mine, many torn wires.
    • If you were like me, it was not as simple as a fuse or breaker. You may need to check your wires coming from the switches on the door, specifically in the door jam.
    • Due to age and wear, you may have a tear (mix-tape dropping soon). OR like mine, many torn wires.
    • Here you need to remove the rubber cover and may need to push wires through kick panel to work on/check wires.
  4. As shown, wires break and simply reconnecting them will restore your windows, seat belt, and/or lock issues.
    • As shown, wires break and simply reconnecting them will restore your windows, seat belt, and/or lock issues.
    • Make sure to reconnect and reassemble everything. Hope this guide helped!
まとめ
2 の人々がこのガイドを完成させました。
Ricky
メンバー登録日: 2013年09月17日
756 ポイント
3のガイドは作成済み
チーム
TechTucson WeFixThat TechTucson WeFixThat人のメンバー
Community
2 メンバー
4のガイドは作成済み
Great to see it first hand. I’m thinking about not risking it and going with a service for my seat belt repair like this one https://www.safetyrestore.com/seat-belt-... .. its much more affordable than a dealership.. any experience with mail in services like this?
David Melnichuk - 返信
David Melnichuk: It appears that that service is in MA, and of course can deal with an issue if you have a part that you can send to them. I am in Seattle, and it’s a seat belt fold-over issue repeatedly interfering with good operation. safetyrestore doesn’t have nationwide branches, does it?
danielbaker2 - 返信
統計データを表示:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 90
今までの合計 7,910
