メインコンテンツにスキップ
How to Repair Nylon Shorts
必要な工具と部品
  1. How to Repair Nylon Shorts, How to Repair Nylon Shorts: 手順 1、 1の画像 1
    • Be sure to choose a thread color that is similar to the garment you are repairing.
    • Thread the needle by stringing the thread through the eye of the needle.
    • Knot the end of the thread and cut off any excess thread. The knot should be large enough to catch the fabric and not pull through.
  2. How to Repair Nylon Shorts: 手順 2、 1の画像 1
    • Take the torn seam into both hands, and overlap one side with the other until both sides are aligned.
  3. How to Repair Nylon Shorts: 手順 3、 1の画像 1
    • Starting from the inside of the garment, pull the needle through the fabric.
    • Pull the thread until the knot catches the fabric.
  4. How to Repair Nylon Shorts: 手順 4、 1の画像 1
    • Make small stitches along the length of the rip.
    • Do not pull the thread too tight or it will cause rippling in the fabric.
  5. How to Repair Nylon Shorts: 手順 5、 1の画像 1
    • Tie the thread as close to the fabric as possible.
    • Cut off any extra thread that is still attached.
終わりに
This guide can be applied to any piece of clothing that has a rip in the seam. Happy stitching!
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Rachel Brockett
メンバー登録日: 10/12/18
145 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team S1-G1, Cools Stephens Fall 2018 Missouri Western, Team S1-G1, Cools Stephens Fall 2018人のメンバー
MWSU-COOLS STEPHENS-F18S1G1
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 44
今までの合計 1,933
