メインコンテンツにスキップ
How to Repair Molded Baseboards
必要な工具と部品
  1. How to Repair Molded Baseboards, How to Repair Molded Baseboards: 手順 1、 1の画像 1
    • Sand the damaged area with the 120 grit sandpaper or a sanding block.
    • Use a utility knife to smooth rougher areas if needed.
  2. How to Repair Molded Baseboards: 手順 2、 1の画像 1
    • Lightly coat the damaged area with wood glue.
  3. How to Repair Molded Baseboards: 手順 3、 2の画像 1 How to Repair Molded Baseboards: 手順 3、 2の画像 2
    • Build up the affected areas with the wood filler. This can be applied with your hands (as individual product safety allows), a spare piece of cardboard, or a popsicle stick.
    • Allow to dry a few hours or overnight (based on product directions).
  4. How to Repair Molded Baseboards: 手順 4、 1の画像 1
    • Cut or fold the 150 grit sandpaper sheet into various pieces to allow proper fit into the various grooves of your baseboard.
  5. How to Repair Molded Baseboards: 手順 5、 1の画像 1
    • Sand the dried wood filler with 150 grit sandpaper.
    • Start from the inside of the baseboard and move out toward the repaired area.
    • Avoid a sawing or back-and-forth motion with the sandpaper to achieve a smooth finish.
  6. How to Repair Molded Baseboards: 手順 6、 1の画像 1
    • Wipe with a slightly damp cloth.
    • Repeat step 3 as needed.
    • Wait at least one hour.
    • Repeat step 6 for the final sanding.
  7. How to Repair Molded Baseboards: 手順 7、 1の画像 1
    • Touch-up with matching paint as needed.
終わりに
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Melanie M. Alter
メンバー登録日: 09/23/21
199 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-2, Friess Fall 2021 University of North Texas, Team 1-2, Friess Fall 2021人のメンバー
UNT-FRIESS-F21S1G2
1 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 48
過去 30 日: 201
今までの合計 8,128
