メインコンテンツにスキップ
How to Repair Doll Eyes
必要な工具と部品
  1. How to Repair Doll Eyes, How to Repair Doll Eyes: 手順 1、 2の画像 1 How to Repair Doll Eyes, How to Repair Doll Eyes: 手順 1、 2の画像 2
    • Remove the doll's head by loosening the neck strings.
    • To loosen the neck strings, turn the doll's head from left to right occasionally pulling the head until you are able to fully pull its head away from the body of the doll.
    • Make sure to remove any fiber fill inside the doll, if it contains the material.
  2. How to Repair Doll Eyes: 手順 2、 1の画像 1
    • Put on disposable gloves.
    • Hold the doll head by the hair so the opening of the head is easily accessible.
    • Pour boiling water into the head and wait for 5 minutes.
    • Pour the hot water out of the doll head.
  3. How to Repair Doll Eyes: 手順 3、 1の画像 1
    • Insert your finger into the doll's head and gently push the eye out from the inside.
    • A dowel rod can also be used but you must be gentle.
    • Careful as the doll's head is very hot!
  4. How to Repair Doll Eyes: 手順 4、 1の画像 1
    • Separate the eyes into the individual parts.
    • Place the parts onto a towel to cool.
  5. How to Repair Doll Eyes: 手順 5、 1の画像 1
    • Rinse the pieces with water and dry them with a towel.
    • Put the eyes back together.
    • After reconstructing the eyes ensure that the they are working properly. Do this by facing the eyeball to the ceiling to close the eyes and facing them towards you to open them.
  6. How to Repair Doll Eyes: 手順 6、 1の画像 1
    • Repeat step 2.
  7. How to Repair Doll Eyes: 手順 7、 1の画像 1
    • Make sure that both the doll's face and the eye sockets are dry before putting the eyes back in.
    • Lay the head flat and place the eye into the eye hole.
    • Push the eye straight down into the hole.
  8. How to Repair Doll Eyes: 手順 8、 1の画像 1
    • Use tweezers to position the eye by grabbing onto the metal part.
    • Avoid using the eyelid to prevent damage.
    • Repeat steps 7-8 for the other eye (if applicable) while the head is still hot.
    • Make some final adjustments to make sure the eyes are positioned correctly.
  9. How to Repair Doll Eyes: 手順 9、 1の画像 1
    • Check if the eyes open and close.
    • Congratulations, you have successfully repaired your doll’s eyes!
ゴール
作成者
1人の作成者と共同作成されました。
Katsa Bejemil
メンバー登録日: 07/02/24
169 ポイント
1ガイドが承認済み
チーム
York University, Team N-6, O'Regan Summer 2024 York University, Team N-6, O'Regan Summer 2024人のメンバー
YORK-O'REGAN-SU24SNG6
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 27
過去 30 日: 132
今までの合計 995
