メインコンテンツにスキップ
How to Repair Cracks in T-Shirt Print
必要な工具と部品
  1. How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: 手順 1、 3の画像 1 How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: 手順 1、 3の画像 2 How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: 手順 1、 3の画像 3
    • Lay your shirt on a flat surface.
    • Use scissors to cut a piece of parchment paper the same size as the design on your shirt.
    • Insert the piece of parchment paper inside of the shirt and under the design.
    • This is to prevent the acetone from staining.
  2. How to Repair Cracks in T-Shirt Print: 手順 2、 3の画像 1 How to Repair Cracks in T-Shirt Print: 手順 2、 3の画像 2 How to Repair Cracks in T-Shirt Print: 手順 2、 3の画像 3
    • Dampen a cotton ball with the acetone.
    • Gently dab the cotton ball onto the cracked area of the shirt and hold it in place for 1 minute.
    • Remember to always dab, do not rub.
    • Repeat this over the whole area that you wish to restore.
    • Let your shirt set for 3-5 minutes
    • If you're doing a small area, let it set for 2-3 minutes. If it is any bigger, set it for 5 minutes.
  3. How to Repair Cracks in T-Shirt Print: 手順 3、 3の画像 1 How to Repair Cracks in T-Shirt Print: 手順 3、 3の画像 2 How to Repair Cracks in T-Shirt Print: 手順 3、 3の画像 3
    • Cut a piece of parchment paper to match the size of the shirt's design, then place it over the design.
    • Turn on a clothes iron to the highest heat setting with NO steam.
    • Be careful when handling the iron, it gets burning hot!
    • When your iron is ready, place it over the parchment paper and go over the whole design once.
    • Go over the areas that had the cracks for at least 10-15 seconds.
  4. How to Repair Cracks in T-Shirt Print: 手順 4、 1の画像 1
    • Now your shirt design should no longer have cracks.
ゴール
作成者
1人の作成者と共同作成されました。
Sitara Cruz-Cuevas
メンバー登録日: 10/14/24
115 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 29-4, Watkins Fall 2024 Austin Community College, Team 29-4, Watkins Fall 2024人のメンバー
AUSTINCC-WATKINS-F24S29G4
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 72
過去 30 日: 349
今までの合計 2,684
