メインコンテンツにスキップ
How to Repair Broken Makeup Powder
必要な工具と部品
  1. How to Repair Broken Makeup Powder, How to Repair Broken Makeup Powder: 手順 1、 2の画像 1 How to Repair Broken Makeup Powder, How to Repair Broken Makeup Powder: 手順 1、 2の画像 2
    • Set a paper towel down on your workspace to catch any spills during the repair process.
    • Using the toothpick, break up the powder into smaller pieces to ensure that all the product is lifted off of the container that it is held in.
  2. How to Repair Broken Makeup Powder: 手順 2、 1の画像 1
    • Dump the broken powder into a bowl, and tap on the side of the bowl to make sure that all the product is falling in.
    • Using the cotton swab, wipe off as much of the remaining product as possible into the bowl.
  3. How to Repair Broken Makeup Powder: 手順 3、 1の画像 1
    • Add 3 drops of isopropyl alcohol into the bowl of powder.
  4. How to Repair Broken Makeup Powder: 手順 4、 1の画像 1
    • Start mixing the powder and isopropyl alcohol together with the spoon.
    • Continue to add 3 drops of isopropyl alcohol to the bowl at a time until all the powder is wet.
  5. How to Repair Broken Makeup Powder: 手順 5、 1の画像 1
    • Clean the container with paper towels and isopropyl alcohol. This will make sure that the completed project will be looking good as new.
    • Scoop all of the product into the spoon and pour it into the clean container.
  6. How to Repair Broken Makeup Powder: 手順 6、 1の画像 1
    • Once all of the product is in the container, smooth down the surface with your finger. Try to soften as many of the bumps as possible.
  7. How to Repair Broken Makeup Powder: 手順 7、 1の画像 1
    • Use the paper towel to clean up the edges of the container.
    • Let the finished product harden by keeping it unopened for 24-48 hours near a window. Then it will be ready to use.
終わりに
The reader will be able to reassemble their broken makeup powder by reading this easy-to-follow tutorial.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Cloe Chin
メンバー登録日: 04/10/19
169 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 552
