メインコンテンツにスキップ
How to Repair A Wet Book
必要な工具と部品
  1. How to Repair A Wet Book, How to Repair A Wet Book: 手順 1、 1の画像 1
    • Be cautious when handling wet books, as books are very fragile when wet and you can accidentally damage front cover, pages, and/or spine.
    • If you do not have time to fix it, immediately put it in a Ziplock bag and place in freezer until you're ready. When you are ready to fix it, lay it on the table and leave it until it thaws.
    • Cover table with plastic sheet or newspapers.
  2. How to Repair A Wet Book: 手順 2、 1の画像 1
    • Lay the book down with the front cover facing up. Place a paper towel over the cover and gently press down on the book.
  3. How to Repair A Wet Book: 手順 3、 2の画像 1 How to Repair A Wet Book: 手順 3、 2の画像 2
    • Be very careful when opening the book, as the spine is very fragile.
    • Gently opening the book to a shallow angle, place paper towels every 10-20 pages in the front half of the book. Place a paper towel on the front cover and press down gently.
  4. How to Repair A Wet Book: 手順 4、 2の画像 1 How to Repair A Wet Book: 手順 4、 2の画像 2
    • Similarly to step 3, gently open the book to a shallow angle and place paper towels in every 10-20 pages towards the last half of the book. Place a paper towel on the front cover and press down.
  5. How to Repair A Wet Book: 手順 5、 1の画像 1
    • Stand the book up, heads or tails, with the pages fanned out.
  6. How to Repair A Wet Book: 手順 6、 1の画像 1
    • To speed up the drying process, leave a fan blowing on it.
  7. How to Repair A Wet Book: 手順 7、 2の画像 1 How to Repair A Wet Book: 手順 7、 2の画像 2
    • If after the book has dried the pages are wavy, lay the book flat and place a board on top of it, along with a couple of heavy books (on top of the board) to help flatten them out. Leave it like this until the pages are completely flattened.
  8. How to Repair A Wet Book: 手順 8、 1の画像 1
    • Great job! The book is now restored to its original condition. Happy reading!
ゴール
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Lizzy Cox
メンバー登録日: 03/07/19
241 ポイント
1ガイドが承認済み
チーム
Missouri Western, Team S1-G8, Cools Stephens Spring 2019 Missouri Western, Team S1-G8, Cools Stephens Spring 2019人のメンバー
MWSU-COOLS STEPHENS-S19S1G8
1 メンバー
3のガイドは作成済み
2件のガイドコメント
because im in middle school. and it is sters full with wet books
Hazen Harwood - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 135
今までの合計 2,096
