メインコンテンツにスキップ
How to Repaint Your Garage Floor
必要な工具と部品
  1. How to Repaint Your Garage Floor, How to Repaint Your Garage Floor: 手順 1、 1の画像 1
    • Use a paint scraper to remove the old paint from the area where you want to apply the new paint.
    • It's okay if there is still some old paint left on the surface.
    • Paint cracks usually indicate corrosion and require scraping.
  2. How to Repaint Your Garage Floor: 手順 2、 1の画像 1
    • Remove debris and dust with a broom.
  3. How to Repaint Your Garage Floor: 手順 3、 1の画像 1
    • Examine the quality of your paint.
    • If it is too thick, and you're using water-based paint, mix in a little bit of water.
    • If it is too thick, and you're using an oil-based paint, add paint thinner.
  4. How to Repaint Your Garage Floor: 手順 4、 1の画像 1
    • Wet the surface of the roller with water.
  5. How to Repaint Your Garage Floor: 手順 5、 2の画像 1 How to Repaint Your Garage Floor: 手順 5、 2の画像 2
    • Pour the paint in a container, dip your roller in, and start rolling.
    • You can also use a paint brush.
  6. How to Repaint Your Garage Floor: 手順 6、 1の画像 1
    • New paint has been applied and you can see the direct contrast.
    • When the paint has dried, reapply a second coat of paint.
  7. How to Repaint Your Garage Floor: 手順 7、 1の画像 1
    • Collect all the tools and prepare them for cleaning.
    • For water-based paint, rinse the tools in water. For oil-based paint, rinse the tools in paint thinner.
    • When rinsing, don't dip your tools in your paint thinner container directly. Instead, pour the paint thinner into another container that can be used for rinsing the tools.
終わりに
Follow these instructions so you can be the next person to learn how to paint.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Chao Zheng
メンバー登録日: 09/20/20
177 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G30, Melo-Thaiss Fall 2020 York University, Team S2-G30, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S2G30
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 33
今までの合計 695
