メインコンテンツにスキップ
How to Remove the Scratches from an Acrylic Watch Face
必要な工具と部品
  1. How to Remove the Scratches from an Acrylic Watch Face, How to Remove the Scratches from an Acrylic Watch Face: 手順 1、 2の画像 1 How to Remove the Scratches from an Acrylic Watch Face, How to Remove the Scratches from an Acrylic Watch Face: 手順 1、 2の画像 2
    • Examine the damage and identify the boundaries for buffing the face of the watch.
    • Working with sandpaper can damage other areas of the watch, so understanding your working area will prevent any careless mistakes.
  2. How to Remove the Scratches from an Acrylic Watch Face: 手順 2、 3の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 2、 3の画像 2 How to Remove the Scratches from an Acrylic Watch Face: 手順 2、 3の画像 3
    • Wipe the watch surface with a paper towel dampened with isopropyl alcohol.
    • It is important to clean the watch of any surface debris to prevent making new scratches.
  3. How to Remove the Scratches from an Acrylic Watch Face: 手順 3、 3の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 3、 3の画像 2 How to Remove the Scratches from an Acrylic Watch Face: 手順 3、 3の画像 3
    • Use the 1000-grit sandpaper, and gently sand the face of the watch in a circular motion.
    • This step is to remove any deep scratches.
  4. How to Remove the Scratches from an Acrylic Watch Face: 手順 4、 3の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 4、 3の画像 2 How to Remove the Scratches from an Acrylic Watch Face: 手順 4、 3の画像 3
    • With your fingernail, feel the surface of the watch for any remaining deep scratches.
    • Keep sanding until you no longer feel scratches.
  5. How to Remove the Scratches from an Acrylic Watch Face: 手順 5、 2の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 5、 2の画像 2
    • Clean the surface again with a paper towel and isopropyl alcohol to prep the watch face for polishing.
  6. How to Remove the Scratches from an Acrylic Watch Face: 手順 6、 2の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 6、 2の画像 2
    • With the tube of polyWatch, place a small dab of the polishing compound on the face of the watch.
  7. How to Remove the Scratches from an Acrylic Watch Face: 手順 7、 3の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 7、 3の画像 2 How to Remove the Scratches from an Acrylic Watch Face: 手順 7、 3の画像 3
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • With the microfiber cloth, begin working on the face of the watch in a circular motion for at least 2-3 minutes.
    • Wipe away any excess compound with a clean cloth and examine your results.
  8. How to Remove the Scratches from an Acrylic Watch Face: 手順 8、 2の画像 1 How to Remove the Scratches from an Acrylic Watch Face: 手順 8、 2の画像 2
    • Repeat the process until you are satisfied with the results.
終わりに
Now, your watch should look close to the day you bought it!
作成者
4人の作成者と共同で作成されました。
Lloyd Derryk Alba
メンバー登録日: 09/20/23
157 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 1-1, Watkins Fall 2023 Austin Community College, Team 1-1, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S1G1
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 71
今までの合計 1,649
