メインコンテンツにスキップ
How to Remove scratches from a CD
必要な工具と部品
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: 手順 1、 1の画像 1
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: 手順 2、 2の画像 1 How to Remove scratches from a CD: 手順 2、 2の画像 2
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: 手順 3、 1の画像 1
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: 手順 4、 3の画像 1 How to Remove scratches from a CD: 手順 4、 3の画像 2 How to Remove scratches from a CD: 手順 4、 3の画像 3
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: 手順 5、 1の画像 1
    • Let the CD sit for 2 to 3 minutes.
  6. How to Remove scratches from a CD: 手順 6、 1の画像 1
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: 手順 7、 1の画像 1
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: 手順 8、 1の画像 1
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
終わりに
44 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nick Jones
メンバー登録日: 09/29/15
1,485 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015人のメンバー
CPSU-GREEN-F15S14G4
5 メンバー
17のガイドは作成済み
5 件のコメント
thank youuuuuuuuu
aboabdo.2007 - 返信
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - 返信
It did not work for me
Leisy Madrigal - 返信
Me Funciono muy bien, gracias!
Esteban Montero - 返信
コメントを追加
統計データ:
過去 24時間: 37
過去 7 日: 257
過去 30 日: 1,003
今までの合計 69,230
