メインコンテンツにスキップ
How to Remove and Replace Caulk in a Bathtub
必要な工具と部品
  1. How to Remove and Replace Caulk in a Bathtub, Replacing Caulk in Bathtub: 手順 1、 1の画像 1
    • Remove current caulk from bathtub using a sharp tool such as a knife or utility tool. Test it first in a small area to not scrape the bathtub.
  2. How to Remove and Replace Caulk in a Bathtub: 手順 2、 1の画像 1
    • Clean the surface and mold from the area with a putty knife. Excess caulk can be removed with a combination of liquid caulk removal. Remove the rest of the residue with a knife.
  3. How to Remove and Replace Caulk in a Bathtub: 手順 3、 1の画像 1
    • Dry the area well to prevent mold from forming and it let it dry overnight before continuing the next step.
  4. How to Remove and Replace Caulk in a Bathtub: 手順 4、 2の画像 1 How to Remove and Replace Caulk in a Bathtub: 手順 4、 2の画像 2
    • Tape around the area that is going to be caulked. Place the tape 1/8 inch on either side of the seam that is going to be caulked. The tape keeps the caulk in a smooth line.
  5. How to Remove and Replace Caulk in a Bathtub: 手順 5、 2の画像 1 How to Remove and Replace Caulk in a Bathtub: 手順 5、 2の画像 2
    • Trim the opening of the caulk from the caulk gun to 1/8 an inch and use it a 45-degree angle and make sure it is the same size as the area between the tape.
  6. How to Remove and Replace Caulk in a Bathtub: 手順 6、 2の画像 1 How to Remove and Replace Caulk in a Bathtub: 手順 6、 2の画像 2
    • Load the caulk gun and use a steady pressure along the space between the tape as you move across it. An even pace is needed; if it’s too slow the caulk will pile up, and if it’s too fast it will break easily.
  7. How to Remove and Replace Caulk in a Bathtub: 手順 7、 1の画像 1
    • Smooth out the line of caulk with your finger.
  8. How to Remove and Replace Caulk in a Bathtub: 手順 8、 2の画像 1 How to Remove and Replace Caulk in a Bathtub: 手順 8、 2の画像 2
    • Remove tape and fix any blemishes.
終わりに
If you are how unhappy how the caulk turned out; don’t worry you can just do the following the steps again as there is no permanent damage done with caulking.
作成者
2人の作成者と共同で作成されました。
Ian Johnson
メンバー登録日: 03/26/20
167 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S5-G13, Willis Spring 2020 University of Memphis, Team S5-G13, Willis Spring 2020人のメンバー
UM-WILLIS-S20S5G13
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 70
今までの合計 2,275
