メインコンテンツにスキップ
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
必要な工具と部品
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 1、 2の画像 1 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 1、 2の画像 2
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 2、 3の画像 1 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 2、 3の画像 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 2、 3の画像 3
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 3、 1の画像 1
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 4、 2の画像 1 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 4、 2の画像 2
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 5、 1の画像 1
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 6、 3の画像 1 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 6、 3の画像 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 6、 3の画像 3
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 7、 2の画像 1 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 7、 2の画像 2
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): 手順 8、 1の画像 1
    • Insert a paper clip and turn until the clog is removed.
終わりに
作成者
2人の作成者と共同で作成されました。
Hector Vazquez
メンバー登録日: 10/23/20
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S12-G11, Harris Fall 2020 CSU Los Angeles, Team S12-G11, Harris Fall 2020人のメンバー
CSULA-HARRIS-F20S12G11
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 534
