メインコンテンツにスキップ
How to Remove a Deodorant Stain From a Shirt
必要な工具と部品
  1. How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: 手順 1、 3の画像 1 How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: 手順 1、 3の画像 2 How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: 手順 1、 3の画像 3
    • Measure two cups of water.
    • Pour the water into a bowl large enough to soak the garment.
  2. How to Remove a Deodorant Stain From a Shirt: 手順 2、 2の画像 1 How to Remove a Deodorant Stain From a Shirt: 手順 2、 2の画像 2
    • Measure 1 cup of white vinegar.
    • Pour the white vinegar into the same bowl with the cup of water.
  3. How to Remove a Deodorant Stain From a Shirt: 手順 3、 2の画像 1 How to Remove a Deodorant Stain From a Shirt: 手順 3、 2の画像 2
    • Soak the garment with the stain in the bowl for 30 minutes.
  4. How to Remove a Deodorant Stain From a Shirt: 手順 4、 3の画像 1 How to Remove a Deodorant Stain From a Shirt: 手順 4、 3の画像 2 How to Remove a Deodorant Stain From a Shirt: 手順 4、 3の画像 3
    • Measure and mix the following ingredients into a small bowl:
    • Half a cup of baking soda.
    • A tablespoon of salt.
    • A tablespoon of hydrogen peroxide.
  5. How to Remove a Deodorant Stain From a Shirt: 手順 5、 1の画像 1
    • Mix the baking soda, salt, and peroxide combination with a small utensil until the ingredients have been thoroughly combined.
    • The result should be a somewhat gritty paste.
  6. How to Remove a Deodorant Stain From a Shirt: 手順 6、 1の画像 1
    • Wring out the shirt and apply the paste to the stain.
    • Be sure to knead the mixture into the fabric to ensure that all of the threads have been exposed.
    • Leave the shirt idle for 20 minutes.
  7. How to Remove a Deodorant Stain From a Shirt: 手順 7、 1の画像 1
    • Wash off the excess paste.
    • Wash the garment in a normal wash cycle.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jeffrey Okhuozagbon
メンバー登録日: 10/02/20
160 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G9, Raign Fall 2020 University of North Texas, Team S1-G9, Raign Fall 2020人のメンバー
UNT-RAIGN-F20S1G9
2 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 32
今までの合計 981
