メインコンテンツにスキップ
How to Remove a Broken and Embedded Screw
必要な工具と部品
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: 手順 1、 1の画像 1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: 手順 2、 2の画像 1 How to Remove a Broken and Embedded Screw: 手順 2、 2の画像 2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: 手順 3、 3の画像 1 How to Remove a Broken and Embedded Screw: 手順 3、 3の画像 2 How to Remove a Broken and Embedded Screw: 手順 3、 3の画像 3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: 手順 4、 3の画像 1 How to Remove a Broken and Embedded Screw: 手順 4、 3の画像 2 How to Remove a Broken and Embedded Screw: 手順 4、 3の画像 3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: 手順 5、 2の画像 1 How to Remove a Broken and Embedded Screw: 手順 5、 2の画像 2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: 手順 6、 3の画像 1 How to Remove a Broken and Embedded Screw: 手順 6、 3の画像 2 How to Remove a Broken and Embedded Screw: 手順 6、 3の画像 3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: 手順 7、 2の画像 1 How to Remove a Broken and Embedded Screw: 手順 7、 2の画像 2
    • Screw the new screw inside the freed hole.
ゴール
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ismael Diaz
メンバー登録日: 10/06/21
217 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 106
過去 30 日: 474
今までの合計 7,890
