はじめに
This guide requires removing the battery. Removing the battery allows no room for electrical malfunction and also makes the process of removing debris easier. If the Halo RIC hearing aid still does not function after these steps, it is advisable to check for electrical or mechanical defects in the microphones.
必要な工具と部品
Detach the receiver from Starkey Halo Receiver-In-Canal hearing aid.
Place the receiver with its small hole away from the surface.
If you know that there is no problem with the receiver and want to clean the microphone, move on to Step 4.
To do this with your other hearing aid, follow the same steps written above. If there is no noticeable change in the RIC Receiver, it is recommended to check for electrical or mechanical defects in the microphone.
5 の人々がこのガイドを完成させました。
