メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Remove Stickers From a Car
必要な工具と部品
  1. How to Remove Stickers From a Car, How to Remove Stickers From a Car: 手順 1、 1の画像 1
    • First of all, find the area where the sticker is. In my case, it is on the car body near the fuel tank.
    FixBotに聞いてみる
    コメントを追加
  2. How to Remove Stickers From a Car: 手順 2、 2の画像 1 How to Remove Stickers From a Car: 手順 2、 2の画像 2
    • Spray the area with some soap water or with cleaning sprays. Goo gone work really well for this and might allow you to skip the blow dryer in the next step.
    FixBotに聞いてみる
    コメントを追加
  3. How to Remove Stickers From a Car: 手順 3、 1の画像 1
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Next, wipe the area thoroughly with a microfiber cleaning cloth. Skip this step if you're using Goo Gone.
    FixBotに聞いてみる
    コメントを追加
  4. How to Remove Stickers From a Car: 手順 4、 2の画像 1 How to Remove Stickers From a Car: 手順 4、 2の画像 2
    • Turn on the hairdryer and put it in its hot setting.
    • Start heating the sticker from a few inches away. Try to heat the sticker from the center outward.
    • This will soften the adhesive under the sticker and make the following steps much easier.
    • Using Goo Gone might allow you to skip this step, but for stubborn stickers, the hair dryer + Goo Gone will be most effective.
    FixBotに聞いてみる
    コメントを追加
  5. How to Remove Stickers From a Car: 手順 5、 3の画像 1 How to Remove Stickers From a Car: 手順 5、 3の画像 2 How to Remove Stickers From a Car: 手順 5、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Use a plastic card and try to scrape the sticker from the edges.
    • A plastic card can help you remove your unwanted stickers without damaging the paint.
    • If it doesn't work, try to repeat step 4 and then try again.
    • If you are working on a glass surface, use a razor blade instead of a plastic card! It may seem too much for the glass, but the glass is hard enough to use a razor blade on.
    • Be careful when using a razor blade!
    FixBotに聞いてみる
    コメントを追加
  6. How to Remove Stickers From a Car: 手順 6、 2の画像 1 How to Remove Stickers From a Car: 手順 6、 2の画像 2
    • Finally, if there is any residue, heat the residue with the hairdryer and scrape it off with a plastic card or razor blade (depending on where the sticker is). Using Goo Gone makes removing any residue easy.
    • After removing all stickers and residue, use some detailing spray or cleaning spray to clean the area again and you are all set!
    FixBotに聞いてみる
    コメントを追加
終わりに
After these steps, you should have a clean surface without any residues!
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Xuanfang Gao
メンバー登録日: 09/15/21
141 ポイント
1ガイドが承認済み
チーム
York University, Team E-7, Melo-Thaiss Fall 2021 York University, Team E-7, Melo-Thaiss Fall 2021人のメンバー
YORK-MELO-THAISS-F21SEG7
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 74
今までの合計 1,959
