メインコンテンツにスキップ
How to Remove Stains From a Porcelain Sink
必要な工具と部品
  1. How to Remove Stains From a Porcelain Sink, How to Remove Stains From a Porcelain Sink: 手順 1、 2の画像 1 How to Remove Stains From a Porcelain Sink, How to Remove Stains From a Porcelain Sink: 手順 1、 2の画像 2
    • Sprinkle water on the sink and use a paper towel to wipe the sink.
    • The sink needs to be a little damp before starting the process so make sure you do not dry it completely.
  2. How to Remove Stains From a Porcelain Sink: 手順 2、 2の画像 1 How to Remove Stains From a Porcelain Sink: 手順 2、 2の画像 2
    • Wear a pair of Vinyl or your cleaning gloves and then sprinkle the baking soda on the damp sink.
    • It is recommended to use a bowl for baking soda. If you use the box directly, you can accidentally drop too much baking soda on the sink.
  3. How to Remove Stains From a Porcelain Sink: 手順 3、 2の画像 1 How to Remove Stains From a Porcelain Sink: 手順 3、 2の画像 2
    • Take a wet sponge and use it to scrub the sink in circular motions. Scrub the harder stains with slightly more force.
    • Make sure you squeeze the sponge beforehand to take out excess water so it is easier to scrub.
  4. How to Remove Stains From a Porcelain Sink: 手順 4、 1の画像 1
    • Wait for 2 minutes and then spray hydrogen peroxide over the sink.
    • If you cannot find hydrogen peroxide then you can also use liquid oxygen bleach as a substitute.
  5. How to Remove Stains From a Porcelain Sink: 手順 5、 1の画像 1
    • Scrub again for another 2-3 minutes. Try to scrub the hard stains with a little force.
  6. How to Remove Stains From a Porcelain Sink: 手順 6、 3の画像 1 How to Remove Stains From a Porcelain Sink: 手順 6、 3の画像 2 How to Remove Stains From a Porcelain Sink: 手順 6、 3の画像 3
    • Take half a lime/lemon and dip it in baking soda and then use it to clean any leftover rust stains.
    • Scrub for 2-3 minutes.
    • This step will also remove the peroxide/bleach smell.
  7. How to Remove Stains From a Porcelain Sink: 手順 7、 2の画像 1 How to Remove Stains From a Porcelain Sink: 手順 7、 2の画像 2
    • Turn the tap on and use the sponge to wipe any leftover stains and residue from baking soda or lemon.
終わりに
The steps in this guide can be repeated often on the sink in order to avoid any lasting stains.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Nishtha Malhotra
メンバー登録日: 01/17/21
175 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G17, O'Regan Winter 2021 York University, Team S1-G17, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S1G17
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 73
今までの合計 2,198
