メインコンテンツにスキップ
How to Remove Scratches from a Car's Interior
必要な工具と部品
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: 手順 1、 2の画像 1 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: 手順 1、 2の画像 2
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
  2. How to Remove Scratches from a Car's Interior: 手順 2、 2の画像 1 How to Remove Scratches from a Car's Interior: 手順 2、 2の画像 2
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
  3. How to Remove Scratches from a Car's Interior: 手順 3、 1の画像 1
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
  4. How to Remove Scratches from a Car's Interior: 手順 4、 1の画像 1
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
  5. How to Remove Scratches from a Car's Interior: 手順 5、 1の画像 1
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
  6. How to Remove Scratches from a Car's Interior: 手順 6、 1の画像 1
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
終わりに
By following these steps you will be able to remove scratches from your cars interior.
作成者
1人の作成者と共同作成されました。
Ryan Vogt
メンバー登録日: 10/08/20
159 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S1-G18, Johnson Fall 2020 Linn Benton Community College, Team S1-G18, Johnson Fall 2020人のメンバー
LBCC-JOHNSON-F20S1G18
1 メンバー
5のガイドは作成済み
2 件のコメント
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - 返信
Any luck finding “grain texture” pads?
ChrisB - 返信
コメントを追加
統計データ:
過去 24時間: 140
過去 7 日: 885
過去 30 日: 3,850
今までの合計 74,954
