メインコンテンツにスキップ
How to Remove Pilling from a Patagonia Sweater
必要な工具と部品
  1. How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 手順 1、 3の画像 1 How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 手順 1、 3の画像 2 How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 手順 1、 3の画像 3
    • Lay the sweater flat on a table. Identify the pilled area of the sweater. It will be covered in little balls of fuzz.
    • Grab your sweater stone.
    • If you ever forget how to remove piling, there is a handy diagram on the back of the box.
  2. How to Remove Pilling from a Patagonia Sweater: 手順 2、 2の画像 1 How to Remove Pilling from a Patagonia Sweater: 手順 2、 2の画像 2
    • Working along the grain of the sweater, gently brush the sweater with the sweater stone.
    • As you use the stone you may notice a funny smell, that is a natural part of the stone which is released as it crumbles away. You will also notice small pieces of debris, as the stone cuts away pills it also breaks apart slowly. Simply shake out the sweater when you are done to remove debris.
    At this point…does all of the “stone debris” come off? Also, what about that smell, does it linger, will it come out with washing? Thank you.
    Nan - 返信
  3. How to Remove Pilling from a Patagonia Sweater: 手順 3、 2の画像 1 How to Remove Pilling from a Patagonia Sweater: 手順 3、 2の画像 2
    • Lift the sweater stone.
    • To prevent snags, always lift the sweater stone when changing directions.
    • Brush the sweater stone the opposite direction along the grain of the sweater.
  4. How to Remove Pilling from a Patagonia Sweater: 手順 4、 2の画像 1 How to Remove Pilling from a Patagonia Sweater: 手順 4、 2の画像 2
    • Continue brushing until the pilling is removed.
    • Clean your sweater stone by rubbing your hand across the stone to remove the lint.
    Will that stone smell be on your hands? How bad is that smell? Thank you.
    Nan - 返信
ゴール
13 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,017 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,198のガイドは作成済み
4 件のコメント
I also have used a disposable razor to shave pills and fuzz off of Patagonia sweaters and capilene - it worked really well. Just lightly run it down the sweater. If any fuzz is persistent, do the same but perpendicular to the first direction you used. It made my sweater and capilene pants look like new again!
AE3 - 返信
Yup, right there with AE3, disposable razor: they last a long time, and they can be re-sharpened a bit by shaving a piece of glass (nothing is disposable). This sweater stone looks kinda like pumice. I’m curious about it, but I wouldn’t buy one.
Rue Koegel - 返信
Can you use a sweater stone on the Nano-Air to remove piling as well?
Trey - 返信
Can't speak to fleece or nano puffs, but with wool sweaters a stone or plucking the pills pulls fibers upward and perpetuates the problem. Best to take scissors and ever-so-carefully, holding them parallel to garment, shear the pills off.
Susan McGrath - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 46
過去 30 日: 208
今までの合計 63,003
