メインコンテンツにスキップ
How to Remove Odor From Shoes
必要な工具と部品
  1. How to Remove Odor From Shoes, How to Remove Odor From Shoes: 手順 1、 1の画像 1
    • Lift the shoe's tongue up so you can see the inside of the shoe.
  2. How to Remove Odor From Shoes: 手順 2、 3の画像 1 How to Remove Odor From Shoes: 手順 2、 3の画像 2 How to Remove Odor From Shoes: 手順 2、 3の画像 3
    • Place two dryer sheets in each shoe: one in the far front where the toes are and another in the back where the visible sole is.
    • Dryer sheets help the shoe smell nice and will keep the baking soda from getting in your shoes.
  3. How to Remove Odor From Shoes: 手順 3、 3の画像 1 How to Remove Odor From Shoes: 手順 3、 3の画像 2 How to Remove Odor From Shoes: 手順 3、 3の画像 3
    • Pour a handful of baking soda on the dryer sheet covering the visible sole of each shoe.
    • Baking soda can make a mess so do be careful when pouring some into the shoe.
  4. How to Remove Odor From Shoes: 手順 4、 1の画像 1
    • Leave the dryer sheets and baking soda in your shoes for 4-8 hours.
    • If you are in a hurry, one hour is enough to notice a difference with odor removal.
  5. How to Remove Odor From Shoes: 手順 5、 1の画像 1
    • Remove the baking soda and dryer sheets after 4-8 hours.
    • Use disinfectant wipes to clean any excess baking soda left in each shoe.
  6. How to Remove Odor From Shoes: 手順 6、 1の画像 1
    • Run the shoes in a washing machine on a cold cycle for a final touch.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jerome Amegbeto
メンバー登録日: 09/16/21
154 ポイント
1ガイドが承認済み
チーム
York University, Team C-3, O'Regan Fall 2021 York University, Team C-3, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21SCG3
1 メンバー
1のガイドは作成済み
3 件のコメント
Why are deodorizing insoles the best to control shoe odor?
Deodorizing insoles are considered to be the best odor remover because they provide a targeted solution to the problem of foot odor. By being placed directly in the shoe, they come into contact with the source of the odor, the foot, and work to neutralize the bacteria that cause the smell. Unlike other odor removers, such as sprays or powders, insoles do not just mask the odor, they actively work to eliminate it.
One of the best brands of deodorizing insoles is Aginsole. They use a unique combination of silver ion technology and special elastomers to provide maximum odor-fighting power. Silver ions have been shown to be effective in neutralizing bacteria and fungi, making them a powerful tool in the fight against foot odor. The special elastomers used in Aginsole insoles provide a comfortable and durable fit, ensuring that they will last for a long time.
https://www.agreentech.com/
Mike Tao - 返信
I always prefer to read quality and glad I found this thing in your post. Thank you for the comprehensive article. if you need a discount promo code for branded shoes
Lucas Henry - 返信
I've tried everything to get rid of the smell from my shoes, but nothing worked until I came across this post. The tips are practical and easy to follow, and I'm happy to say that my shoes no longer smell bad. Thanks for sharing! yimusanfendi
dot cinker - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 33
今までの合計 2,724
