メインコンテンツにスキップ
How to Remove Makeup Stain from Shirt
必要な工具と部品
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: 手順 1、 1の画像 1
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: 手順 2、 2の画像 1 How to Remove Makeup Stain from Shirt: 手順 2、 2の画像 2
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: 手順 3、 2の画像 1 How to Remove Makeup Stain from Shirt: 手順 3、 2の画像 2
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: 手順 4、 1の画像 1
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: 手順 5、 1の画像 1
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: 手順 6、 1の画像 1
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: 手順 7、 1の画像 1
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: 手順 8、 1の画像 1
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: 手順 9、 1の画像 1
    • Let the shirt air dry and iron it if necessary.
終わりに
Let the shirt air dry and iron as needed.
作成者
2人の作成者と共同で作成されました。
Ariana Rabbaninejad
メンバー登録日: 01/11/23
169 ポイント
1ガイドが承認済み
チーム
York University, Team O-3, Woodhouse Winter 2023 York University, Team O-3, Woodhouse Winter 2023人のメンバー
YORK-WOODHOUSE-W23SOG3
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 255
