メインコンテンツにスキップ
How to Remove Crinkles in a Jump Rope
必要な工具と部品
  1. How to Remove Crinkles in a Jump Rope, How to Remove Crinkles in a Jump Rope: 手順 1、 2の画像 1 How to Remove Crinkles in a Jump Rope, How to Remove Crinkles in a Jump Rope: 手順 1、 2の画像 2
    • Clean the jump rope if it’s dirty or used, and remove the handles.
  2. How to Remove Crinkles in a Jump Rope: 手順 2、 3の画像 1 How to Remove Crinkles in a Jump Rope: 手順 2、 3の画像 2 How to Remove Crinkles in a Jump Rope: 手順 2、 3の画像 3
    • Fill 3/4 of a large pot with water.
  3. How to Remove Crinkles in a Jump Rope: 手順 3、 1の画像 1
    • Set the pot on a stove and let it reach boiling temperature.
    • Caution: Be careful when handling boiling water since it can cause burns when handled incorrectly. Have an adult help you if needed.
  4. How to Remove Crinkles in a Jump Rope: 手順 4、 3の画像 1 How to Remove Crinkles in a Jump Rope: 手順 4、 3の画像 2 How to Remove Crinkles in a Jump Rope: 手順 4、 3の画像 3
    • Place a large bucket outside.
    • Place the crinkled jump rope into the bucket.
  5. How to Remove Crinkles in a Jump Rope: 手順 5、 2の画像 1 How to Remove Crinkles in a Jump Rope: 手順 5、 2の画像 2
    • Carefully pour the boiling water into the bucket.
    • Caution: Boiling water can cause burns, so please handle with care.
  6. How to Remove Crinkles in a Jump Rope: 手順 6、 2の画像 1 How to Remove Crinkles in a Jump Rope: 手順 6、 2の画像 2
    • Let the jump rope sit with the boiled water in the bucket for about 3 to 5 minutes.
    • Remove the jump rope with a pair of tongs and place them on the ground.
    • Let the jump rope cool down enough to handle but be sure that it is still warm.
  7. How to Remove Crinkles in a Jump Rope: 手順 7、 3の画像 1 How to Remove Crinkles in a Jump Rope: 手順 7、 3の画像 2 How to Remove Crinkles in a Jump Rope: 手順 7、 3の画像 3
    • Find a circular object to wrap the jump rope around and slowly apply force to pull and hold it for about 2 minutes.
    • Your jump rope should now be free of crinkles and be ready to use.
    • If you still have some crinkles in the jump rope, feel free to stack weights on top of it and let it sit overnight, or follow the guide over again to get a more refined rope.
ゴール
作成者
1人の作成者と共同作成されました。
Fernando Pedro
メンバー登録日: 03/20/21
148 ポイント
1ガイドが承認済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 46
今までの合計 1,660
