メインコンテンツにスキップ
How to Remove Calcium Buildup from a Shower Head
必要な工具と部品
  1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: 手順 1、 2の画像 1 How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: 手順 1、 2の画像 2
    • Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
    • You may be able to loosen the shower head by hand.
    • Handle carefully because the shower head may be heavy.
  2. How to Remove Calcium Buildup from a Shower Head: 手順 2、 1の画像 1
    • Use your hands to finish unscrewing the bolt.
    • Remove the shower head from the wall spout.
  3. How to Remove Calcium Buildup from a Shower Head: 手順 3、 3の画像 1 How to Remove Calcium Buildup from a Shower Head: 手順 3、 3の画像 2 How to Remove Calcium Buildup from a Shower Head: 手順 3、 3の画像 3
    • Pour one cup of water into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the water.
  4. How to Remove Calcium Buildup from a Shower Head: 手順 4、 3の画像 1 How to Remove Calcium Buildup from a Shower Head: 手順 4、 3の画像 2 How to Remove Calcium Buildup from a Shower Head: 手順 4、 3の画像 3
    • Pour one cup of distilled vinegar into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the solution.
    • If using the vinegar solution provided in steps 3 and 4 fails to provide adequate results, you may want to repeat the steps using CLR (Calcium, Lime, and Rust) solution instead.
  5. How to Remove Calcium Buildup from a Shower Head: 手順 5、 2の画像 1 How to Remove Calcium Buildup from a Shower Head: 手順 5、 2の画像 2
    • Place the shower head face down into the plastic bag of vinegar solution.
    • Let the shower head sit for one hour before removing it from the plastic bag of vinegar solution.
  6. How to Remove Calcium Buildup from a Shower Head: 手順 6、 1の画像 1
    • After one hour, remove the shower head from the plastic bag of vinegar solution.
    • Use a metal sponge to scrub in a circular motion to remove the treated calcium on the shower head.
    • Excessive scrubbing could damage the finish.
  7. How to Remove Calcium Buildup from a Shower Head: 手順 7、 2の画像 1 How to Remove Calcium Buildup from a Shower Head: 手順 7、 2の画像 2
    • Place the shower head under running water to remove any extra calcium left behind.
    • If calcium is still present, repeat steps 5 through 7 as needed.
  8. How to Remove Calcium Buildup from a Shower Head: 手順 8、 2の画像 1 How to Remove Calcium Buildup from a Shower Head: 手順 8、 2の画像 2
    • Clamp the adjustable wrench onto the bolt of the shower head.
    • Turn the adjustable wrench clockwise to tighten the shower head back onto the water spout.
ゴール
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jacob Abrego
メンバー登録日: 02/23/16
150 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team 26-6, Rauch Spring 2016 Texas Tech, Team 26-6, Rauch Spring 2016人のメンバー
TTU-RAUCH-S16S26G6
3 メンバー
4のガイドは作成済み
1件のガイドコメント
How to remove rust stain (from iron) from bathroom tiles?
waihong yeung - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 54
今までの合計 9,919
