メインコンテンツにスキップ
How to Refurbish White Adidas Continental 80 Shoes
必要な工具と部品
  1. How to Refurbish White Adidas Continental 80 Shoes, How to Refurbish White Adidas Continental 80 Shoes: 手順 1、 1の画像 1
    • Take the laces out of both shoes before cleaning.
    • The laces can be either hand-washed or put through the washer and dryer after the shoes are cleaned.
  2. How to Refurbish White Adidas Continental 80 Shoes: 手順 2、 1の画像 1
    • Wet the brush in soapy water.
    • Brush the base of the shoe horizontally and vertically.
    • Wet the brush multiple times to keep enough soapy water on the shoe.
  3. How to Refurbish White Adidas Continental 80 Shoes: 手順 3、 1の画像 1
    • Brush the top and different sections of the shoe.
    • Continue with circular, vertical, and horizontal brushing motions to ensure the best results.
  4. How to Refurbish White Adidas Continental 80 Shoes: 手順 4、 1の画像 1
    • Make sure to clean the tongue in the same circular, horizontal, and vertical motions with the toothbrush.
    • Use lots of soapy water on the tongue.
  5. How to Refurbish White Adidas Continental 80 Shoes: 手順 5、 1の画像 1
    • Grab a new bowl with warm water and wet the hand-towel to remove the dirt accumulated by the soapy water.
    • Wet and wipe multiple times to remove excess soap from the shoe.
  6. How to Refurbish White Adidas Continental 80 Shoes: 手順 6、 1の画像 1
    • Set the right shoe aside and move on to the left shoe.
  7. How to Refurbish White Adidas Continental 80 Shoes: 手順 7、 1の画像 1
    • Brush the base and sides in the same circular, horizontal, and vertical motions with the toothbrush.
  8. How to Refurbish White Adidas Continental 80 Shoes: 手順 8、 1の画像 1
    • Brush the top and tongue of the left shoe.
    • Continue rinsing and re-wetting the toothbrush in soapy water.
  9. How to Refurbish White Adidas Continental 80 Shoes: 手順 9、 1の画像 1
    • See if there are any other areas of the shoe you might need to clean again.
  10. How to Refurbish White Adidas Continental 80 Shoes: 手順 10、 1の画像 1
    • Soak the laces in the same soapy water you used to clean your shoes for 30-40 minutes.
  11. How to Refurbish White Adidas Continental 80 Shoes: 手順 11、 1の画像 1
    • Soak the laces in clean water for 30-40 minutes to clean off the soap.
    • Soak the laces at room temperature to prevent the laces from shriveling up.
  12. How to Refurbish White Adidas Continental 80 Shoes: 手順 12、 1の画像 1
    • Let the laces air dry for 1-2 hours or put them in the dryer for 20 minutes.
  13. How to Refurbish White Adidas Continental 80 Shoes: 手順 13、 1の画像 1
    • Let your shoes sit out to air dry for an entire day.
    • Avoid putting shoes in the dryer unless you have protective material around your shoes to prevent damage.
終わりに
Having clean shoes is important to a lot of people. Know that this technique is a simple, easy technique with simple materials used. There are plenty of more in-depth, expensive techniques that may clean the shoes a lot better than this technique does.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Samir Ochoa
メンバー登録日: 10/20/20
244 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S14-G5, Cowan Fall 2020 Texas Tech, Team S14-G5, Cowan Fall 2020人のメンバー
TTU-COWAN-F20S14G5
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 29
過去 30 日: 87
今までの合計 4,351
